Allis 314 Hydro axle seals
1 reply to this topic
#1 Leonard VanCamp OFFLINE
Leonard VanCamp
    Deere Herder
  • 1059 Thanks
  • 673 posts
Posted March 11, 2015 - 08:33 PM
Does anybody know of a sources where I can get two axle seals for a Allis 314 Hydro? My uncle has one and I have noticed lately that his axle seals are starting to leak and I would like to replace them. Thank You.
#2 JDBrian OFFLINE
  • 9681 Thanks
  • 14162 posts
Posted March 12, 2015 - 07:22 AM
Something to check when you have axle seals leaking on a hydro tractor is that the hydro is venting properly. If the vent is plugged pressure will build up and force fluid out of the weakest seals, which typically will be the axle seals in an older tractor. If you can't find the vent just carefully remove the fluid filler cap after the tractor has been run for a while and see if any pressure is released as the cap is loosened. I had this happen on a JD314 I bought. The vent was blocked and the transmission was over filled. When I removed the filler cap fluid shot out a foot in the air and I was lucky not to have gotten any in my eyes.
