SAND IN TIRES
36 replies to this topic
#16 MH81 OFFLINE
Posted March 11, 2015 - 05:54 PM
I would like to try this. Get as much jammed in a tire as I can and add some anticoagulant.
#17 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 11, 2015 - 06:00 PM
I heard dumping in a gallon of WD40 keeps it from clumping, like David mentioned.
It would seem to me that rim guard would nut be much more costly than wd40?
Would not freeze,or wear out the rims?
  • Auburn David said thank you
#18 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 11, 2015 - 06:09 PM
Some here use transmission fluid..I never tried it.
#19 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 11, 2015 - 06:11 PM
Fluids and sand flows...sorta like when your at the beach and dig a hole...
#20 IamSherwood OFFLINE
  • 8,391 Thanks
Posted March 11, 2015 - 06:19 PM
If you dig up the sand on the gulf shores, don't you get BP oil injected sand?
  • Gtractor, grnspot110, KennyP and 2 others have said thanks
#21 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted March 11, 2015 - 06:22 PM
Looks like I asked a good question. I thought I was gonna get laughed at.
Somebody got to try this and see how well it works.
  • IamSherwood and Auburn David have said thanks
#22 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted March 11, 2015 - 06:24 PM
It might flow in Alabama, but with the sub zero temps, I hAd to plow snow in up here riding on steel wheels would be smoother.
I thought the chains on frozen ground was rough enough!
  • backwoods said thank you
#23 MH81 OFFLINE
Posted March 11, 2015 - 06:41 PM
I have the sand if the winter didnt remove it.
Just need to dry it out and get the time to put it in a couple of tires.
#24 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted March 11, 2015 - 06:45 PM
So what's the best fluid to mix with it, or better just DRY sand?
#25 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 11, 2015 - 06:57 PM
Just enough fluid to keep the sand moving has worked for me..
#26 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 11, 2015 - 06:59 PM
Be sure its PLAY SAND...or beach sand(don't really recommend beach sand because of the salt)
#27 BTS ONLINE
BTS
    Make Stuff Up
  • 4,250 Thanks
  • 2,456 posts
Posted March 11, 2015 - 11:01 PM
I wonder how much weight is to much, I have a bolens HT23 that I'd like to try this on, I already have front wheel weights (20lbs each)  and rear weights (40lbs each). I don't know if it would be overkill to fill the rear tires with sand or not? I don't want to damage the GT but it would also be nice having the weight because this GT spends a lot of time in the garden and pushing a lot of material with the blade.
Anyone know what a 24x12x12 would weigh?
#28 TUDOR OFFLINE
TUDOR
  • 563 Thanks
  • 506 posts
Posted March 12, 2015 - 02:57 AM
.From Rim Guards Hydro-flation chart, 24x12-12 tires will hold 7.5 gallons at a 75% fill level.
Dry Sand = 100 lb/cu-ft, or 13.3 lb/gal.
A gallon of liquid could be added without adding volume. The liquid would fill the voids between sand grains.
Calcium Chloride and water = 11.3 lb/gal.
Rim Guard = 10.3 lb/gal.
Water = 8.3 lb/gal.
Windshield washer antifreeze = 7.5-8.1 lb/gal.
ATF = 6 lb/gal.
For ease of installation, least potential damage, cost per pound, and most weight, I'd go with Rim Guard.
Beach sand around Lake Ontario doesn't have much salt in it. There's even less in the sand from the inland lakes.
  • DH1 said thank you
#29 MH81 OFFLINE
Posted March 12, 2015 - 07:01 AM
So, assuming TUDOR's math is as usual right... That's about 100# a tire.
That's a lot of weight for fill.
#30 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 12, 2015 - 09:58 AM
I am not recommending anyone use the sand,I am just saying we do it here with no problem.
