SAND IN TIRES
36 replies to this topic
#1 DH1 ONLINE
DH1
    Electric Tractors
  • 5,356 Thanks
  • 5,603 posts
Posted March 10, 2015 - 05:51 PM
I heard/read somewhere about using Sand instead of Liquids in tires for extra weight. ???
Anybody know anything about doing this or have any opinions about it?
Does it work?
#2 gopher OFFLINE
gopher
  • 768 Thanks
  • 760 posts
Posted March 10, 2015 - 05:54 PM
Not a good idea. Over time wear your tire and rim out.
  • DH1 and Gtractor have said thanks
#3 Gtractor ONLINE
Gtractor
    the homeless tractor hoarder
  • 9,640 Thanks
  • 5,044 posts
Posted March 10, 2015 - 06:04 PM
Yeah but the inside of the tire would be polished to a beautiful shine - for a little while.....  :poke:
  • DH1, grnspot110 and backwoods have said thanks
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted March 10, 2015 - 06:12 PM
Not only what has been said but as the sand collects condensation, I would think it would freeze (it doesn't get THAT cold in Canada, does it?) with a flat spot on the bottom.  I couldn't even think of a good way to get it in there.
  • DH1 and IamSherwood have said thanks
#5 KC9KAS OFFLINE
KC9KAS
  • 5,443 Thanks
  • 4,710 posts
Posted March 10, 2015 - 06:15 PM
One grain at a time through the valve stem. :bigrofl:
That ought to keep you busy for a while! :hitting_self_roller:
  • DH1, KennyP, Cvans and 3 others have said thanks
#6 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 10, 2015 - 06:20 PM
We do it down here all the time...Play sand..works good...never had an issue..but we dont get real cold.Most folks that use it mix it with washer fluid anyway.
  • DH1, Alc and Coventry Plumber have said thanks
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 10, 2015 - 06:22 PM
Ya do have to break the tire from the bead to install it in a timely fashion..and add some WD-40.
  • Alc and Cat385B have said thanks
#8 glgrumpy OFFLINE
  • 8,707 Thanks
  • 7,972 posts
Posted March 10, 2015 - 08:30 PM
Now wouldn't that get thrown around in big "thumps" when you moved? Wanna keep pushing when you want to stop then and such? Can't imagine being able to fill very full and still work tire on?? If you could go fast, would throw out and level out, but not gonna do that on a tractor. Be like toys you may have had with out of round wheels then. No?
  • DH1 and Auburn David have said thanks
#9 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 10, 2015 - 08:35 PM
Already mentioned, my concerns would be frozen sand, causing a
spastic ride, and wear on the rim/tire.
Also, if you ever where to cross the border, and head west, there's a pretty
good chance, that the smell of damp sand will attract Cat, and he'd rip the
rubber of the rims and leave you a present. :(
  • DH1, MH81, Texas Deere and Horse and 3 others have said thanks
#10 DH1 ONLINE
DH1
    Electric Tractors
  • 5,356 Thanks
  • 5,603 posts
Posted March 10, 2015 - 08:46 PM
I never thought of that, I don't have much experience with Cats. ???
  • KennyP and Auburn David have said thanks
#11 3v0 OFFLINE
3v0
  • 117 Thanks
  • 103 posts
Posted March 10, 2015 - 08:47 PM
If the sand is added with fluid that does not freeze the only problem I see is the abrasion.  No idea how much of a problem that would be.  But I have enough problems with dirt getting between the tire and the rim as it is.
A friend bought a new tractor and they ballasted his tires with molasses.  New to me.
#12 UncleWillie OFFLINE
  • 16,100 Thanks
  • 8,905 posts
Posted March 10, 2015 - 09:06 PM
Might be a good way to sandblast the wheels. LOL.
Never heard of it before. Seems like it would work down here in the south better than in yankeeland.
#13 Cat385B ONLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted March 10, 2015 - 09:08 PM
I heard dumping in a gallon of WD40 keeps it from clumping, like David mentioned.
  • DH1, MH81 and Auburn David have said thanks
#14 MH81 OFFLINE
Posted March 10, 2015 - 09:28 PM
Interesting read on the topic. Patent on using very fine particles over coarse for better ride and flex.
http://www.google.co...tents/US2884039
#15 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 11, 2015 - 09:58 AM
We have had good luck with it down here.might be cause we don't know it isn't suppose to work...LOL
  • KennyP and toppop52 have said thanks
