6 gallons of Rotella...
4 replies to this topic
#1 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 10, 2015 - 04:47 PM
Could never figure out how much hydraulic oil the Frankin tractor(ingersoll 6018 Digit 188T) took..so I am the proud owner of 6 gallons of Rotella T 20w50!
  • MH81, KennyP and Coventry Plumber have said thanks
#2 MH81 OFFLINE
Posted March 10, 2015 - 05:03 PM
Please let us know how much it takes.
  • Auburn David said thank you
#3 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted March 10, 2015 - 05:04 PM
I hope that's enough!
#4 ING6018 OFFLINE
ING6018
  • 2 Thanks
  • 2 posts
Posted March 12, 2015 - 03:57 PM
According to the Ingersoll 6018 user manual:
  A loader uses 8 quarts to refill, or 13 quarts (total system).
  A LBH uses 8 quarts (refill) and 20 quarts (total system).
So, on a LBH, the system uses 8, the loader cylinders use 5, then the backhoe uses 7.
Assuming the Dig-It hoe has similar capacities to the Ingersoll version, ~5 gallons gets you close. However, if you just drain and refill (8 quarts) then you are leaving ~12 quarts of old/unk fluid in the tractor and backhoe cylinders.
Dan
#5 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 12, 2015 - 04:02 PM
Naaa I am going to drain and flush the whole system..so I am hoping I am close..thank you for the info!
