Briggs and Stratton opposed twin stripping starter gears
3 replies to this topic
#1 CraftsmanGT OFFLINE
CraftsmanGT
  • 222 Thanks
  • 265 posts
Posted March 10, 2015 - 02:56 PM
Model 422707 type 1228-01. Brand new starter
and solenoid. I'm getting about 6 months out of a
starter gear using genuine Briggs gears. I noticed
some wear on flywheel ring gear, I can see the
teeth are slightly thinner where the starter gear
meshes. Could this be the problem? Thanks
#2 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted March 10, 2015 - 04:23 PM
I would say that would be the best place to start. If the teeth have some damage then it will not take long for the plastic gear to be damaged. I guess the damage to your gear is the teeth correct. You can replace the ring gear on the flywheel and I stock new ones for around $45 for the briggs one not aftermarket.
  • Alc, superaben and Sawdust have said thanks
#3 Sawdust ONLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted March 10, 2015 - 08:00 PM
I would say your ring gear that worn is like a chainsaw up against the plastic starter gear.
#4 CraftsmanGT OFFLINE
CraftsmanGT
  • 222 Thanks
  • 265 posts
Posted March 11, 2015 - 02:11 PM
That's comfirms what I thought. Thanks everyone
