Welding question
60 replies to this topic
#1 HDWildBill OFFLINE
  • 8,984 Thanks
Posted March 08, 2015 - 05:54 PM
Over the past 9 months and especially this winter I have been teaching my self how to weld.  One problem I have is when I strike and arc I can't see what I'm doing all I see is the arc.  So I can't how well I'm doing or in what direction I'm going.  Quite often I find my self going in the wrong direction.  Any guidance would be appreciated.
  • Alc, Texas Deere and Horse, hamman and 3 others have said thanks
#2 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,011 posts
Posted March 08, 2015 - 05:58 PM
Have same problem when no good light on project. A good spotlight on arm works good over the bench. OR, the shade glass in helmets can be changed to lighter or darker shade. Most for arc are #10, but many others available. Don't want to go too light or is bad as staring at welder w;out glasses would be over long time. Check with your Weld supply stores for those shades. OR......weld out side or by the door with good old daylight coming in at the project. Not so easy in winter, heh!
  • Alc, hamman, HDWildBill and 1 other said thanks
  • 14,887 Thanks
  • 15,514 posts
Posted March 08, 2015 - 06:05 PM
Bill, try to look at the base of the arc, I can see what I am welding by looking at the puddle. You might want to try a shade lighter lens also.
#4 tater195 OFFLINE
tater195
  • 2,264 Thanks
  • 1,443 posts
Posted March 08, 2015 - 06:06 PM
Most auto darkening helmets are adjustable, but can be alittle pricey
  • hamman, HDWildBill and WNYTractorTinkerer have said thanks
#5 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 08, 2015 - 06:10 PM
Yes, they're pricey, but well worth it.
Bill, are you mig, or stick welding?
I couldn't mig until I got the auto dark.
#6 propane1 ONLINE
propane1
  • 9,434 Thanks
  • 4,379 posts
Posted March 08, 2015 - 06:13 PM
Use an auto darkening helmet. Adjustable welding shades for electric welding, 9 to 13, I think and if you don't turn the helmet on, it has a standard shade of 4. So if its not on and you strike a spark , if won't hurt your eyes as bad and you can use # 4 for bronze or steel welding with gasses. Noel
  • Alc, Texas Deere and Horse, hamman and 1 other said thanks
#7 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 08, 2015 - 06:14 PM
I can always see what I am welding just by using the light of the arc..you really have to concentrate..
  • hamman and HDWildBill have said thanks
#8 esbbent OFFLINE
esbbent
  • 448 Thanks
  • 260 posts
Posted March 08, 2015 - 06:16 PM
I just recently picked up auto darkening helmet from HF for $40. I used it yesterday for the first time welding up a MF12, it makes a world of difference with the wire welder.
  • hamman, HDWildBill, WNYTractorTinkerer and 2 others have said thanks
#9 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted March 08, 2015 - 06:17 PM
Try a set of 1 1/2 magnifiers in your helmet. Did wonders for me. I have an auto darkening helmet as well and still had a hard time seeing with it set at 9. Also try marking  the area you are going weld with a soap stone. Will not affect the weld.
Edited by Kyocum, March 08, 2015 - 06:22 PM.
  • Alc, hamman, IamSherwood and 3 others have said thanks
#10 HDWildBill OFFLINE
  • 8,984 Thanks
Posted March 08, 2015 - 06:25 PM
Will, I'm mig welding,  I bartered with a buddy for a Lincoln weldpack 100.
I do have an HF auto darkening helmet and I've played with the adjustment on the side but I can't really see the puddle. I've tried to use a light on the work bench but that didn't help much. I do wear glasses so maybe the magnifiers are what I need.
  • Alc, hamman, IamSherwood and 2 others have said thanks
#11 propane1 ONLINE
propane1
  • 9,434 Thanks
  • 4,379 posts
Posted March 08, 2015 - 06:31 PM
Turn the wire speed a little faster that may help, just a thought. Noel
  • hamman, HDWildBill and boyscout862 have said thanks
#12 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 08, 2015 - 06:33 PM
I have to wear cheaters (readers) inside the helmet, or else I end up
welding the part to the bench, or even worse, to my belt buckle.
  • Alc, hamman, HDWildBill and 4 others have said thanks
#13 boyscout862 ONLINE
  • 13,546 Thanks
  • 9,427 posts
Posted March 08, 2015 - 06:42 PM
Bill you should be able to see what you are doing by the light of the arc. I generally get myself in position and practice the seam direction so that my hands can get the "feel" of what I want to do. I then lower my mask and pull the trigger. I always push the MIG and drag a stick. Practice your bead to get the right heat and feed adjustments on scrap. Good Luck, Rick
Try http://www.lincolnel...or-manuals.aspx   for the manual.
Edited by boyscout862, March 08, 2015 - 07:04 PM.
  • Alc, hamman, HDWildBill and 2 others have said thanks
#14 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,597 Thanks
  • 2,908 posts
Posted March 08, 2015 - 06:45 PM
Not trying to hijack this thread, however I to have a hard time seeing. I use a TS auto darkening and wire weld and stick weld on 13 ! Is that my problem I have it to dark? It will not take a magnifier. Again sorry for the question in wild bills thread. Thanks. I'll listen now.        Roger
  • Alc, HDWildBill, boyscout862 and 1 other said thanks
#15 Nato77 OFFLINE
Nato77
    Old Iron Junky
  • 1,683 Thanks
  • 1,353 posts
Posted March 08, 2015 - 06:46 PM
If your mig welding try positioning yourself so that most of the arc is hid behind the nozzle when welding. I end up doing it that way so I can see where I'm going.
  • hamman, IamSherwood, HDWildBill and 2 others have said thanks
