Pto problems on my iseki
pto problems
13 replies to this topic
#1 Gee OFFLINE
Gee
  • 2 Thanks
  • 4 posts
Posted March 08, 2015 - 11:06 AM
hi I'm new Gt talk and I'm having problems with my bolens iseki g154 tractor 4x4 3cyl garden tractor the pto stops turning when I put a load on it with the snowblower and when I take it out of the snow it slowly starts to turn any one know what the problem is And can help out even with a diagram I would appreciate it thank you bryan
  • MH81 and Cvans have said thanks
#2 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted March 08, 2015 - 11:13 AM
Welcome to GTtalk.  I moved your thread to the Bolens forum where I think you will get an answer to your question.  Some of the Bolen's guys should be along before long.
  • MH81 and boyscout862 have said thanks
#3 Gee OFFLINE
Gee
  • 2 Thanks
  • 4 posts
Posted March 08, 2015 - 11:22 AM
. Thanks
#4 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted March 08, 2015 - 11:31 AM
Welcome,there should be someone here that's up on them,I think there are 3 belts inside the housing,sounds like an ajustment issue,
#5 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 08, 2015 - 12:08 PM
Does the engine lug down at all, or remain at full rpm's?
#6 Gee OFFLINE
Gee
  • 2 Thanks
  • 4 posts
Posted March 08, 2015 - 12:24 PM
. Hi it stays at a high rpm
#7 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted March 08, 2015 - 12:29 PM
Is there a clutch on the pto? Discs or belts or ??  Sounds like you need adjustment?
#8 boyscout862 OFFLINE
  • 15273 Thanks
  • 10026 posts
Posted March 08, 2015 - 02:31 PM
Welcome to GTT. Check in our Manuals Section for the Manual. Good Luck, Rick
#9 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted March 08, 2015 - 03:44 PM
Welcome to GTTalk. The Iseki's are gear driven off of the transmission to the PTO. Here is a video of a guy with a G154. Good luck.
http://youtu.be/4c_-zVZj9mo
#10 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 08, 2015 - 04:54 PM
When you engage the front/mid pto lever, when can you start to feel the resistance? Mine starts almost immediately, probably in the first inch or so. It is fully engaged by the time the lever is just past halfway.
If yours is not engaging similarly, try adjusting the cable tension using the sleeve nut on the cable in front of the pto engagement lever. If that doesn't work, or if that doesn't seem to be the issue, then break out the 17mm, 10mm, and that big hex socket (can't remember the size of that one) and pull the front apart.
I think there are 3 belts inside the housing, sounds like an adjustment issue.
That's correct, triple belted from a pulley off the crank to the front/mid pto shafts.
  • Gtractor, MH81 and blackjackjakexxix have said thanks
#11 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted March 08, 2015 - 10:05 PM
Welcome here. I can't remember who but someone here just spent months completely rebuilding their Iseki Bolens from the ground up and will be able to help you with some insight. Good luck.
#12 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 09, 2015 - 08:49 AM
Member Fxrs55 is who you're thinking of. His does not have the front pto kit.
  • Cvans said thank you
#13 Cvans ONLINE
  • 9628 Thanks
  • 7321 posts
Posted March 09, 2015 - 09:56 AM
That's a bummer.  :mad2:
#14 Illusmare OFFLINE
Illusmare
  • 2 posts
Posted June 20, 2019 - 09:53 AM
Seems my Iseki 2160XT also has some problem with front PTO. Is it supposed to run constantly or is it operated with same lever as rear PTO? Rear PTO seems to work normally but even when PTO is in off position and rear stops spinning the front keeps spinning.
