Honda Regulator Substitute
honda regulator rectifier regulator rectifier gx610 gx620 gx670 charging
5 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted March 07, 2015 - 01:06 PM
I need a regulator/rectifier for my Honda GX610, but new ones are $100 +.  It's a 20 amp regulator with 2 leads for the AC input, one lead to the battery, and grounded through the aluminum case.  There are several Honda models that work--most are upgrades.  The most current models are 31620-zg5-023 which supersedes to 31620-zg5-033.
It has a short pigtail with a connector housing and 6 spade terminals (see picture).
Would another 20 amp regulator with similar wiring work for this? I'm thinking something from a motorcycle, another GT, etc.
I have no problem splicing in terminals, wiring, etc.
Thanks,
Smitty
Edited by Utah Smitty, March 07, 2015 - 01:07 PM.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 07, 2015 - 03:14 PM
http://www.ebay.com/...=item35e5f144ac
  • Utah Smitty said thank you
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 07, 2015 - 03:16 PM
any of those work?
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 07, 2015 - 03:22 PM
You might also look over these for bikes and 4 wheelers..I have a friend who uses the ones for 4 wheelers somehow..
http://www.ebay.com/...=p2045573.m2388
  • Alc and Utah Smitty have said thanks
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted March 07, 2015 - 11:39 PM
any of those work?
Thanks for checking.  The eBay item was just a rectifier... I need the voltage reg as well...
Regards,
Smitty
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted March 07, 2015 - 11:42 PM
Now there may be something here... some of the cases look identical to the GX610 reg/rec, and the same number of leads--for a third the price... go figure...
Smitty
Also tagged with one or more of these keywords: honda, regulator rectifier, regulator, rectifier, gx610, gx620, gx670, charging
