Sears SS/16 will an Onan P224 fit?
7 replies to this topic
#1 1oldbuzz OFFLINE
1oldbuzz
  • 487 Thanks
  • 406 posts
Posted March 07, 2015 - 05:49 AM
Tried searching came up empty
Scored a nice Onan P224 runs nice
Will this beast fit in my SS/16?
Has anyone done this
looking for tips on whats needed
This one has the deep sump oil pan
which makes it stand taller than my BF
Can I swap over the BF pan to the P24
unless I have enough clearance for the hood
I wouldn't need to
quick measurement also looks to be 4 inches wider
Stretch the hood at the nose joint?? and a longer belt?
Just looking for input
Thanks
Sorry can't test fit tractor is in pieces going threw a refurbish.
#2 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 283 Thanks
  • 229 posts
Posted March 07, 2015 - 07:54 AM
whats crank size for pulley. the 16hp is 1 1/8 by like 3.
#3 jms180 ONLINE
jms180
  • 1,357 Thanks
  • 1,499 posts
Posted March 07, 2015 - 08:56 AM
The P224 is a beast. That is 24 HP. Nice find. Be sure to add pictures later
#4 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted March 07, 2015 - 09:08 AM
I've never worked on a P224, so I don't know if pans can interchange or not.  I believe they can on the P220.
#5 KennyP ONLINE
  • 36,460 Thanks
  • 44,943 posts
Posted March 07, 2015 - 09:29 AM
I did a little research and the pans & gaskets have different #'s. I know that doesn't mean a lot, but you never know. I was hoping they had the same gasket #'s.
#6 olcowhand ONLINE
  • 39,676 Thanks
  • 30,972 posts
Posted March 07, 2015 - 09:33 AM
All I know is that I DID put a BF pan on a P220 block.  It's the engine on my Massey "2055" (modified MF1650).
#7 1oldbuzz OFFLINE
1oldbuzz
  • 487 Thanks
  • 406 posts
Posted March 07, 2015 - 03:55 PM
Thanks for the replies
Did some measuring between the P24 and the BF
4-5 inches wider
and 5-6 inches taller
Clamped and bolted some of the frame back together
to see
Well not going to fit
Not unless I make a new front frame section.
But not all was lost
Neighbor came over seen the P24
asked if I would sell
as he needed a new engine for his skidder
I did well
  • olcowhand, MH81 and TomLGT195 have said thanks
#8 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted March 08, 2015 - 01:53 AM
Glad you were able to move it along and get it a new home.
Now, the search continues.
