Simplicity landlord
28 replies to this topic
#1 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 05, 2015 - 07:24 PM
Well I found a barn find tonight not sure of the year motor is free but it doesn't seem to have any compression
  • rustyoldjunk, Gtractor, Texas Deere and Horse and 6 others have said thanks
#2 KennyP ONLINE
  • 37,526 Thanks
  • 45,518 posts
Posted March 05, 2015 - 07:33 PM
That looks interesting!
  • tinbender7 said thank you
#3 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 05, 2015 - 07:40 PM
1964
#4 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 05, 2015 - 07:43 PM
I couldn't read the numbers on the motor they are behind the front grill
#5 Tomwendt OFFLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted March 05, 2015 - 07:47 PM
whats hanging off the back of that?
#6 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 05, 2015 - 07:54 PM
No idea I'm almost sure that part is not factory
#7 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted March 05, 2015 - 08:17 PM
Could be a carboned up stuck open exhaust valve causing no compression.
#8 petrj6 ONLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted March 05, 2015 - 08:56 PM
   sweet find !!!  looks complete with both side covers and the headlight bracket.  I bet with soap and water that will clean up real nice and be a great worker.  keep us informed as to how you make out with it.
        Pete
#9 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,421 Thanks
  • 1,855 posts
Posted March 05, 2015 - 08:59 PM
Missing lift lever. thing on the back looks like a 3 point of some kind. homemade i'd say
#10 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 05, 2015 - 09:09 PM
I have been looking at the pictures I took of it I noticed the lift lever was missing and I'm not sure the hydro lift on it is right because the cylinder should be under it if im right not on the right side of it as you can see in the first picture of it but if I'm wrong please someone correct me
#11 classic ONLINE
classic
  • 5,177 Thanks
  • 2,234 posts
Posted March 05, 2015 - 09:20 PM
Nice find! It should have a Briggs 23D engine in it.As others have said, a stuck valve is probably the reason for no compression. I would remove the engine and remove the engine covers to give it a good cleaning and inspection. Also remove the head and inspect the cylinder and check the valves. Clean and adjust the points and test for spark before putting the engine back in. Coils are available for your armature if your coil is bad. These Briggs engines are prone to having mouse nests in them when they sit and it can cause the engine to overheat. The mice have a taste for wire insulation, too. That tractor will look much better once you clean the grunge off of it. The '64 Landlord is one of my favorites.
#12 glgrumpy OFFLINE
  • 8,564 Thanks
  • 7,881 posts
Posted March 05, 2015 - 09:24 PM
Man, lots of little stuff laying all around in that barn. Might wanna look around and see if anything more should go with it? That rear mount looks similar to a plow frame, just missing back half??
#13 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted March 05, 2015 - 10:09 PM
It has a dozer snow blade that come with it I did notice that the original head light mounts are still there
#14 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted March 05, 2015 - 10:22 PM
9 HP
#15 HANKG OFFLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted March 06, 2015 - 12:27 AM
Nice find got one just like it except for the hydraulic rear lift you have. looks like it might clean up pretty well good luck with her. Hank
