A Horse and a Mouse
18 replies to this topic
#1 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 05, 2015 - 06:47 PM
A 1971 WH Raider 10 is my current project.
Look what I found when I took the hood off and
put it upside down on my workbench...
Mr. Mouse was storing mouse poison in the
headlight buckets.  I thought it was supposed
to KILL him!....Was he storing it up so he could
commit suicide  later?
:wallbanging:
Edited by WHdbJD, March 05, 2015 - 06:47 PM.
  • rustyoldjunk, Gtractor, Alc and 4 others have said thanks
#2 KennyP ONLINE
  • 31,350 Thanks
  • 41,564 posts
Posted March 05, 2015 - 07:08 PM
Smart Mouse!
  • tinbender7 said thank you
#3 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted March 05, 2015 - 07:17 PM
This is exactly why I don't buy that style anymore. They just cart it off and hoard it.
The bait bars work much better IMHO, mainly because they eat it there.
  • KennyP, tinbender7 and WHdbJD have said thanks
#4 glgrumpy ONLINE
  • 7,203 Thanks
  • 6,918 posts
Posted March 05, 2015 - 07:25 PM
I've always used old fashion traps with peanut butter on them.  Put a few around, seems to work!  Best you pull shroud on engine now and look for nest. OR at least try to blow out around flywheel opening and the head fins. Then when you start, watch the junk fly out of there!  My experiences.
  • KennyP and tinbender7 have said thanks
#5 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 06, 2015 - 06:50 AM
Two good ideas for getting the critters.   I'll have to check all the GTs for mouse nests
when I get them out this spring.
Anyway here's some "before" pics of my WH project
#6 twostacks OFFLINE
twostacks
  • 450 Thanks
  • 427 posts
Posted March 06, 2015 - 09:24 AM
I'm surrounded by oak trees and I always have acorns shooting out of the mufflers on my equipment that sits all winter. Along with mice I get chipmunks too. I think they are the culprits for the acorns. I tried leaving the barn door cracked open for the local cats to get in and hunt but all they did was pee on everything. I have to use the poison bricks because the critters were doing the same thing that you ran into.
#7 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 09, 2015 - 04:51 PM
Found no more hiding places for Mr Mouse snacks as work progresses
on the WH  Raider 10 project;
Since the weather was co-operating today, did a partial teardown and
power wash to get rid of most of the crud.....
It cleaned up pretty nice, considering I had no detergent for a pre-soak.
#8 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 09, 2015 - 05:08 PM
Wheel Horse aficionados, here's a question for you...
Can I replace the leaking seal behind the transmission pulley without
splitting the case, and if so , how?
#9 GWest OFFLINE
GWest
  • 467 Thanks
  • 424 posts
Posted March 11, 2015 - 12:02 PM
Sure you can. Poke a hole in the side of it with an awl or ice pick and with that alone you may be able to pry it out. Or start a small sheet metal screw into it and pull out with pliers. Make sure you don't mark the shaft. Polish the shaft so there are no nicks around the key slot, oil up the seal and slide it in. A piece of tubing the size of the seal works well to tap it in. That seal is likely only 1/8" deep so they twist easily without a tube.
Garry
  • WHdbJD, LilysDad and Sawdust have said thanks
#10 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 11, 2015 - 02:41 PM
Great , thanks Garry.
Did some more teardown and cleaning today;
Parts awaiting their turn for a bath...
#11 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted March 30, 2015 - 03:26 PM
Weather was more springlike today , so I did some more
powerwashing;
full work table;
more partz
#12 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,741 Thanks
  • 8,256 posts
Posted March 30, 2015 - 03:39 PM
:wallbanging:
I would check my coffee before consuming.
  • WHdbJD said thank you
#13 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted April 01, 2015 - 07:14 PM
here's the WH Raider 10 frame I painted with primer today.
I don't have much success painting outside, seems like
everytime I try it, the breeze kicks up and takes
half my paint across the yard, or the bugs decide they
like my fresh paint. I'm gonna do the rest of the WH
project in the shop!
  • Sawdust said thank you
#14 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted April 11, 2015 - 05:40 PM
Progress report on the WH Raider 10 project;
Sandblasted and primered rear wheels today
Put final coat of IH red on frame and transaxle parts
#15 WHdbJD OFFLINE
WHdbJD
  • 634 Thanks
  • 481 posts
Posted April 24, 2015 - 06:49 PM
more progress,
snagged a pair of 23X9.5X12 Carlisle turfs NOS for $74
Edited by WHdbJD, April 25, 2015 - 02:13 AM.
