Honda GX 610 Engine--Need Flywheel Bolt Pattern
honda gx610 v-twin engine conversion stub shaft front pto
5 replies to this topic
#1 Utah Smitty ONLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted March 05, 2015 - 06:07 PM
I just traded a pistol for a Honda GX610 with only 75 hours on it.  Also got a 1800 watt belt-driven generator...
I'm planning to put this into one of my tractors, but I need to build a stub shaft to go from the 3 hole bolt circle on the flywheel to a clutch, U-joint, etc.
Has anyone ever made one of these, or know the dimensions?  The stub shaft can be purchased, but they're about $250...
Regards,
Smitty
#2 KennyP ONLINE
  • 41,524 Thanks
  • 47,427 posts
Posted March 05, 2015 - 06:59 PM
Maybe something in here has the dimensions you seek!
  • Utah Smitty said thank you
#3 dthomp17 ONLINE
dthomp17
  • 614 Thanks
  • 485 posts
Posted March 05, 2015 - 07:36 PM
Smitty, I put a Honda gx610 in my sears SS/16 about two years ago.  I have a PDF service manual that's in four different languages that I can email you if you think it would be of any help.
Don
#4 Utah Smitty ONLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted March 06, 2015 - 12:01 AM
Don
Thanks Don, I'd appreciate it.  Send me a PM and I'll give you me email address.
Smitty
#5 Utah Smitty ONLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted March 06, 2015 - 12:14 AM
Thanks, Kenny.  There's a lot of good dimensional info for the engine and PTO side, and also some links to adapters to go between the Honda and Kohlers, Onans, etc. They're still about $110 delivered, so I'm going to work on it some more.
I pulled the shroud off the engine tonight and measure the bolt circle... I think I'm pretty close at 2.125"  this equals 54 mm so it's a round figure in both cases.
Regards,
Smitty
#6 Utah Smitty ONLINE
Utah Smitty
  • 1,713 Thanks
  • 1,793 posts
Posted March 07, 2015 - 01:00 PM
Well, near as I can tell, the bolt circle is 2.44" or 62mm, FWIW.  It appears to use 8mm bolts--which are just a tad larger than 5/16".
Smitty
Also tagged with one or more of these keywords: honda, gx610, v-twin, engine conversion, stub shaft, front pto
