Peerless Model 2311 Transmission Help
4 replies to this topic
#1 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted March 04, 2015 - 06:18 PM
Hey Guys,
Looking for a little guidance as I am not well versed in transmissions. I have a 1967 Speedex S18 that I am working on restoring and it needs some attention in the transmission. As i said, it is a peerless 2311 transmission and the input shaft had a lot of play. I figured out that it was the bearings that were bad on that. In the process of removing the hubs, i may have screwed something up. I had really use some force to get the hubs off and i think i broke those little rings on the axle you see in the picture. I downloaded manuals from here, but from those pictures, I can't really tell what broke. I think the gears and everything else looks ok though. Also, are parts still available for this? I need almost every oil seal and these mysterious rings, not to mention the bearings for the input shaft. Thanks in advance guys, I appreciate it.
Mike
  • Bolens 1000 and superspeedex have said thanks
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted March 04, 2015 - 06:26 PM
I assume the ring your looking at is in picture 1? If so that looks to be a toasty thrust bearing :D
If you have part numbers I can see what is available,  There are lots of parts still available through peerless but I can also check for more affordable alternatives as well as I can deal direct for National/Timken seals and bearings which is usually alot cheaper than the peerless packaged parts.
  • tinbender7 said thank you
#3 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted March 04, 2015 - 06:33 PM
Haha yes it is the broken rings in the top left of the first photo. I saw a similar piece on the axle in picture 2
#4 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 05, 2015 - 08:54 AM
yeah those are thrust bearings superaben sells rebuild kits with the seals but he can also get you other parts
http://gardentractor...kits-available/
Edited by superspeedex, March 05, 2015 - 08:55 AM.
  • GTpicker01 said thank you
#5 GTpicker01 OFFLINE
GTpicker01
    GT Addict
  • 706 Thanks
  • 593 posts
Posted March 05, 2015 - 12:15 PM
Thanks for the Info! I'll pm him and see what he has to say!
