help help! need part numbers for bearing and seal
15 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 03, 2015 - 06:54 PM
Need part numbers for the bearing and seal for the 90 degree gear box that drives the impeller. It is the end that the cog goes on to drive the impeller. Not ford numbers, they no longer carry parts for these old things. Any information would be great. Noel
More snow coming !!!
#2 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,280 posts
Posted March 03, 2015 - 06:55 PM
If you have the ford numbers I can see if I can interchange them for you.
I am a National/Timken dealer
  • propane1 said thank you
#3 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 03, 2015 - 07:14 PM
Sorry I don't have the ford numbers. , but I know from going to the local unfriendly ford dealer before, that they don't carry or want to look up any thing on these old machines. Noel.
#4 KennyP ONLINE
  • 40,891 Thanks
  • 47,096 posts
Posted March 03, 2015 - 07:55 PM
Got a model # for that blower?
#5 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 03, 2015 - 08:49 PM
I will get it tomorrow. Noel.
#6 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted March 03, 2015 - 11:20 PM
Are there #s stamped in the bearing and outer race? If so a brg supply store should be able to help you. If the seal is separate from the brg, using calipers get the shaft OD where the seal lip runs and get the ID of the housing the seal goes in and finally get the thickness of the seal body and take those dimensions to the brg supply store.
Mike
#7 JBRamsey OFFLINE
JBRamsey
  • 1,568 Thanks
  • 878 posts
Posted March 04, 2015 - 12:52 AM
Stonebreaker is right. Take your measurements or better yet your shaft and the housing to your bearing dealer. They can mic them and look up a seal by the dimensions. I always take my parts because some seals are deeper and may not seat properly in your housing. Bearings almost always have numbers stamped on them. Any decent parts house can cross them over.
#8 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 04, 2015 - 05:41 AM
No numbers on the bearing or seal. Will go to bearing store and see what they can do. Noel
#9 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 04, 2015 - 06:42 AM
Blower numbers are. 09JC9895
59895T5550
#10 KennyP ONLINE
  • 40,891 Thanks
  • 47,096 posts
Posted March 04, 2015 - 07:57 AM
I just ran that model through Messick's site (New Holland). All the bearings are the same in that box. But they are proud of that bearing.
Bearing #: TEC780034 - $69.70
Seal #:  TEC788029A - $6.09
They have one bearing in stock!
  • bhts, JDBrian and propane1 have said thanks
#11 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted March 04, 2015 - 08:02 AM
Man those are pricey. I thought the ones in a JD 49 angle drive were high at 33$ ea. My guess is they can cross those for you at a bearing supplier and they will almost certainly be much less than 70$ ea.
  • KennyP and propane1 have said thanks
#12 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted March 04, 2015 - 08:29 AM
I have the same bearing at $34.80 each but the seal is a little cheaper as we have them for $8.99
#13 Bolens 1000 ONLINE
  • 15,423 Thanks
  • 18,280 posts
Posted March 04, 2015 - 08:30 AM
Thanks Kenny!
I forgot those are peerless numbers. I actually Have these parts instock go figure! :wallbanging:
Bearing 780034 $ 14.03ea
Seal 788029A    $ 8.05
#14 KennyP ONLINE
  • 40,891 Thanks
  • 47,096 posts
Posted March 04, 2015 - 09:00 AM
Just trying to help out here guys!
There you go Brad! If it were me, I'd replace all bearings in there while it's down!
  • Bolens 1000 said thank you
#15 propane1 ONLINE
propane1
  • 9,444 Thanks
  • 4,385 posts
Posted March 04, 2015 - 03:47 PM
Thanks for all the help.  I got one at our local bearing supplier. $10.38 for the bearing and $6.09 for the seal.  Bearing is a National brand, number is R14.  Noel
New Holland wanted $106.oo. Wow what a difference.
Edited by propane1, March 04, 2015 - 03:49 PM.
