Experimental Hydraulics
hyhydraulics experiment
41 replies to this topic
#31 KennyP ONLINE
  • 37,539 Thanks
  • 45,526 posts
Posted March 04, 2015 - 05:13 PM
Years ago when I worked in the oil fields, we would put a diverted valve on our pickups power steering pump and run the line back to a hydraulic winch in the bed of the truck. These would lift 3500 lbs. I am sure some of you have seen the electric version of these in pickups. It never failed to lift the weight.
First I have heard of that!
  • Chopperhed said thank you
#32 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted March 04, 2015 - 05:40 PM
Kenny if your intrested we have a 2008 F450 with a front winch run off the p/s I could find out more about it
  • KennyP, bgkid2966 and Chopperhed have said thanks
#33 KennyP ONLINE
  • 37,539 Thanks
  • 45,526 posts
Posted March 04, 2015 - 05:44 PM
Enlighten us, Al! Start a thread on it. Just never heard of that before.
  • Alc and Chopperhed have said thanks
#34 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted March 04, 2015 - 05:52 PM
No problem ,I'll see what info we have on file at my work location if not there should be something in the main shop where the vehicle first gets put in service
  • KennyP and Chopperhed have said thanks
#35 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 04, 2015 - 06:09 PM
Taps into your rig's power steering pump for longer, cooler and more reliable pulls than traditional electric winches http://www.autoanyth...0A2271A0A0.aspx
mile_marker_winch_h12000_hydraulic_winch
#36 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 04, 2015 - 06:13 PM
  • Alc, KennyP and Chopperhed have said thanks
#37 KennyP ONLINE
  • 37,539 Thanks
  • 45,526 posts
Posted March 04, 2015 - 06:14 PM
They are proud of that thing!
  • Chopperhed and Auburn David have said thanks
#38 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 04, 2015 - 06:15 PM
Yes they are..but I am sure one could be built lots cheaper.
#39 Alc ONLINE
  • 6,751 Thanks
  • 7,399 posts
Posted March 05, 2015 - 09:07 AM
Your faster then I could get the info ,  lol here's the brand we use .
  • Bruce Dorsi, KennyP, Cvans and 2 others have said thanks
#40 KennyP ONLINE
  • 37,539 Thanks
  • 45,526 posts
Posted March 05, 2015 - 09:51 AM
Thanks, Al! Cool stuff!
#41 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted March 05, 2015 - 10:39 AM
[quote name="Bmerf" post="549935" timestamp="1425487706"]Can you explain how to modify?[/quogte]
Pull out the high pressure fitting and it will have a funky fitting/ orifice looking piece. You can increase vol ume by simply drilling out these holes, but DONT MAKE THE TOO BIG or you will ruin it.to increase pressure you can either find a tougher spring, or add a few shims under one end, but again, more is not always better,as it could cause all kinds of failures,pump shaft, relief valve body,pump housing, hoses, and even kill your engine when something is applied.
We used to do this very thing when we would build ram assist steering on our rock crawler rigs. Works very well. We would also tap two ports into the steering gear box that would then be run to the ram.
#42 KennyP ONLINE
  • 37,539 Thanks
  • 45,526 posts
Posted March 06, 2015 - 11:03 AM
I moved this thread to our new Mechanical and Hydraulics Forum.
