Experimental Hydraulics
hyhydraulics experiment
41 replies to this topic
#1 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 03, 2015 - 04:23 PM
I need to add another hydraulic system to my crawler conversion. Even Princess auto pumps run $190.00  for small pumps that can take a side load.
I picked up a power steering pump out of a 95 caravan and hooked it up to a 1/2hp electric motor.
A simple wet circuit with a gauge told me that at 1050 rpm, the pump put out 850psi before it stalled the motor and blew the breaker.
I'm thinking this thing might be ok for the crawler, if not, I'll figure something out for it.
#2 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 04:27 PM
I have a Nice pump from a International Harvester combine that would be perfect for your project I believe.
#3 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 04:28 PM
its about half the size of the pump your using.
#4 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 04:29 PM
Getting it over the boarder would be an issue though..LOL
#5 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 03, 2015 - 05:03 PM
Shipping always sux, so do the duties and exchange
Actually most of the size of the pump is a small reservoir. the little reservoir up top holds about a pint. I plan on replacing the filler reservoir with a 5" x 10 round tank. I think with another 2 gallons in a remote reservoir, it will be more than adequate for what I'm doing. The total volume of all the cylinders combined is only a few pints. I'm not really worried about cylinder speed, cause it will only take a few seconds to move a 1-1/2 bore cylinder the distance I need. the longest cylinders I have are 8" stroke.
With a 1-1./2" bore and a 1" rod, the up side should be pretty quick, down force should be slower and more controllable. angling will be fast 1-1/4" bore x 6" stroke 1" rod, both at the same time might be slow.
#6 Cvans ONLINE
  • 7,282 Thanks
  • 6,376 posts
Posted March 03, 2015 - 05:09 PM
The power steering pumps that I've use have worked excellent for running lift cylinders.
  • Alc, boyscout862 and Auburn David have said thanks
#7 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted March 03, 2015 - 05:11 PM
Do you have a picture of the one you have??  I pulled one this past fall from one of our dead combines along with the tank for the fluid.
#8 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 05:19 PM
I will have to try and get a picture of it..or some #s off it.
  • Chopperhed said thank you
#9 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted March 03, 2015 - 05:27 PM
That's a neat way to check one out. I need to get a gauge to test with.
#10 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted March 03, 2015 - 05:28 PM
If you want to sell it, I might be interested. Hint! Hint!
  • Auburn David said thank you
#11 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 05:39 PM
#12 Auburn David OFFLINE
Auburn David
  • 2,756 Thanks
  • 1,962 posts
Posted March 03, 2015 - 05:42 PM
  • Cvans said thank you
#13 IamSherwood OFFLINE
  • 8,395 Thanks
Posted March 03, 2015 - 06:01 PM
You need a new disc on your sander.( pic 1 & 2 )
Princess Auto has them on sale at times.
  • KennyP and Chopperhed have said thanks
#14 KennyP ONLINE
  • 40,880 Thanks
  • 47,091 posts
Posted March 03, 2015 - 06:02 PM
Might be fun to find a pulley for that!
  • Cvans and Auburn David have said thanks
#15 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted March 03, 2015 - 07:38 PM
The gauge cost me 15 bucks, but it's something I can use everywhere, given my choice of hobbies.
