Another locomotive project
71 replies to this topic
#1 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 03, 2015 - 01:54 PM
In the thread I just did on the brass locomotive, I had talked about getting started on trains by "kitbashing" the plastic steam engines that were available back in the 70's.
The main engine kit that I used was a model of the Indiana Harbor Belt 0-8-0 locomotive.
These were made in Italy by Rivarossi and sold by AHM.
The model kit was sold with plastic wheels and they made a motorizing kit that had metal wheels to replace the plastic ones.
Here is what that engine looked like when assembled with the motorizing kit.
Over the years I have managed to collect several of these plastic engine kits and the motorizing kits to go with them.
Using parts from a couple of these model kits, I would like to build a model of an Erie Railroad  0-8-8-0 Camelback  steam locomotive like this.
These are the main parts that will be used to build the engine.
An engine boiler shell and a tender shell.
Two frames, one with the motorizing kit already on it and an extra motorizing kit for the second frame.
Some miniscules plastic parts and metal side rods and valve linkage parts.
A cast brass boiler piece for a Camelback locomotive ( this will also add the necessary weight in the back to balance the engine so it isn't to front heavy ).
A piece of plastic pipe to use for extending the boiler.
The first step is to cut the front part off the frame that will be used as the rear chassis.
Then I cut the rear part off the frame that will be used as the front chassis.
I formed this piece out of sheet brass.
It will attach the two chassis units together with the brass shoulder bolt.
The brass piece fits on the back of the front chassis frame for the pivot between the two chassis frames.
This is a view of the underside of the two frames attached.
Here are the two frames set upright.
  • grnspot110, Texas Deere and Horse, hamman and 17 others have said thanks
#2 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted March 03, 2015 - 02:02 PM
Wow, that's really impressive!  Nice work so far.  I'll be following this one.
  • jdcrawler and tinbender7 have said thanks
#3 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 10,976 Thanks
  • 8,389 posts
Posted March 03, 2015 - 02:03 PM
At the rate your going, your going to need a new hobby to stay busy.
#4 KennyP OFFLINE
  • 32,186 Thanks
  • 42,011 posts
Posted March 03, 2015 - 02:11 PM
All right! Another cool build to follow! This ought to be different!
  • jdcrawler, IamSherwood and tinbender7 have said thanks
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted March 03, 2015 - 03:36 PM
Im Subscribing this should be a neat build
#6 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted March 03, 2015 - 06:23 PM
Sweet Ray, another build. :dancingbanana:
Looking forward to following along.
That was a monster of a machine.
Do you have any specs on it? They're probably mind boggling.
#7 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 03, 2015 - 07:01 PM
Specifications
road: Erie
class: L-1
builder: American Locomotive Co (Schenectady, NY)
date built: July 1907
number built: three
road numbers: 2600, 2601, 2602
rebuilt (by Baldwin, 1921): to 2-8-8-2
scrapped: December 1930
cylinders (front): 39" d  x  28" s (simple)
cylinders (rear): 25" d  x  28" s (compound)
wheel arrangement: 0-8-8-0 (articulated)
driver diameter: 51"
boiler diameter (min): 84"
steam pressure: 215 p.s.i.
grate area: 100 sq. ft.
heating surface (total): 5313.6 sq. ft.
weight (on drivers): 410,000 lbs.
weight (total): 410,000 lbs.
tractive force: 94,070 lbs.
Edited by jdcrawler, March 03, 2015 - 07:09 PM.
  • Texas Deere and Horse, IamSherwood, KennyP and 4 others have said thanks
#8 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted March 03, 2015 - 07:15 PM
Thanks Ray.
Yep, that's mind boggling.
I bet the ground moved, when that rolled through town.
#9 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 04, 2015 - 03:54 PM
The cast brass firebox has a stub section of boiler on the front of it.
The plastic pipe that I'm going to use for the boiler is just a little larger diameter than the stub section on the firebox so I can bore the end of the plastic pipe out to fit on the firebox.
Unfortunately, I only have the small hobby lathe so I can't put the whole boiler in it.
I cut a short piece off the end of the plastic pipe and chucked it up in the lathe to bore out the end.
This end piece now fits over the end of the firebox.
The end piece is then glued back onto the end of the boiler.
I scribed a line on the side of the plastic pipe before I cut the end piece off so I could align the two pieces back the same way.
Starting to make the mounting base for the firebox out of styrene sheet.
Lining up the boiler on the chassis.
#10 KennyP OFFLINE
  • 32,186 Thanks
  • 42,011 posts
Posted March 04, 2015 - 05:08 PM
Looks good. Will that be the finished length for this?
  • jdcrawler said thank you
#11 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 04, 2015 - 05:30 PM
That is the finished length of the boiler.
The locomotive and tender will be about 25 inch long when it is all built.
Here is a straight on side view of the locomotive.
Edited by jdcrawler, March 04, 2015 - 05:36 PM.
  • Texas Deere and Horse, KennyP, MFDAC and 3 others have said thanks
#12 KennyP OFFLINE
  • 32,186 Thanks
  • 42,011 posts
Posted March 04, 2015 - 05:45 PM
That's a lot of boiler!
#13 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 06, 2015 - 02:00 PM
After doing a little research I came across this explanation of why these locomotives were built this way.
" The Reading, Lehigh Valley, CNJ and several other roads used camelbacks in all types of service including passenger.
The reason for the wide firebox was so the anthracite coal used by these railroads would burn more efficiently. Anthracite is a very hard coal compared to the bituminous coal used by most roads and required more air and a thinner layer of coal on the grates to burn properly.
The disadvantage was that they were so wide the cabs had to be located over the boiler exposing the fireman to all the elements and causing a communications problem between him and the engineer. "
  • Texas Deere and Horse, KennyP and Sawdust have said thanks
#14 jdcrawler OFFLINE
jdcrawler
    tinkerer
  • 3,264 Thanks
  • 1,740 posts
Posted March 06, 2015 - 05:18 PM
Right now the top of the boiler is even with the top of the firebox.
You can see in this drawing that the top of the firebox sets higher than the boiler and the rear portion of the boiler flairs out going into the firebox.
Using automotive body fill, I added height to the top of the firebox and tapered it down to blend with the boiler.
Here is the finished boiler.
#15 LilysDad ONLINE
LilysDad
  • 10,976 Thanks
  • 8,389 posts
Posted March 06, 2015 - 05:47 PM
It must have been uncomfortably hot riding that close to the boiler.
