looking for manual for 1989 pk with 4-speed tranmisson parts
25 replies to this topic
#1 bob0usa OFFLINE
bob0usa
  • 20 Thanks
  • 27 posts
Posted March 03, 2015 - 11:32 AM
looking for manual for 1989 pk with 4-speed tranmisson parts break down, all manuals that i find on line are all for the 3 speed!  I need bearing for a input shaft on the 4-speed!
thanks to all!! :wave:
  • David Brown and SammieCync have said thanks
#2 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted March 03, 2015 - 12:51 PM
I have a parts break down for a 4 speed PK tranny but I need to know the serial number of your tractor to be sure the one I have is correct.  This one is for serial number 62750 and up.
  • Username and bob0usa have said thanks
#3 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 03, 2015 - 07:17 PM
I have the service manual but it is 72,130 KB and to big to send.
  • KennyP and bob0usa have said thanks
#4 glgrumpy ONLINE
  • 7,164 Thanks
  • 6,883 posts
Posted March 03, 2015 - 09:30 PM
I might have some of that info, but will have to look later. I have a thumb drive and also the Big Red Book which should have it in them. Mission Manufacturing in Evansville, IN might have those parts. They are the owner's of what is left of PK and have much in later model parts. OR, should just be a common stock bearing and seal would think and can get at any good bearing shop with numbers off the bearing or in a parts diagram. Going to work now, have to look better tomorrow.
  • bob0usa said thank you
#5 KennyP OFFLINE
  • 31,236 Thanks
  • 41,497 posts
Posted March 04, 2015 - 07:35 AM
Have you tried to upload it to the PK manual section?
#6 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 04, 2015 - 08:27 AM
I tried but the file is to large.
  • KennyP, bob0usa and abu507 have said thanks
#7 glgrumpy ONLINE
  • 7,164 Thanks
  • 6,883 posts
Here is a parts scan for latest info I have. There is some shading/highlighting done on it by someone. I have also found a 7 page manual on removing and working on the trans.  I will have to do that one later again.
  • bob0usa and abu507 have said thanks
#8 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 04, 2015 - 08:30 AM
This is just the transmission.
#9 KennyP OFFLINE
  • 31,236 Thanks
  • 41,497 posts
Posted March 04, 2015 - 08:35 AM
If I can remember how to use Drop Box, I can get it that way. Is there a way you can break that manual into two parts?
#10 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted March 04, 2015 - 08:44 AM
That's the one I have.  I just thought it would be good to verify what he has before we throw too much at him.
#11 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 04, 2015 - 08:59 AM
I don't know how to do it but there might be a program that could do it.I'll send you a PM.
#12 Username OFFLINE
Username
  • 2,069 Thanks
  • 1,425 posts
Posted March 04, 2015 - 09:00 AM
Mine has the serial number listed so hopefully he can confirm it with his if he ever stops back.
  • KennyP, David Brown and bob0usa have said thanks
#13 glgrumpy ONLINE
  • 7,164 Thanks
  • 6,883 posts
Posted March 05, 2015 - 08:22 PM
OK, scanned those file pages. I didn't open Usernames but might be same one?? Not sure how clear they will be. Manual shows older version and newer version, thinking the reverse idler is the diffrerence?  Didn't study to check. Sorry I don't know how to make files to load, this is best I can do. I did just download Usernames file and it IS the same, Oh, well!
Edited by glgrumpy, March 05, 2015 - 08:30 PM.
  • KennyP, MNGB and bob0usa have said thanks
#14 KennyP OFFLINE
  • 31,236 Thanks
  • 41,497 posts
Posted March 06, 2015 - 07:17 AM
Thanks for the pics, GL! I could make that into a PDF real easy, but not a need here!
#15 bob0usa OFFLINE
bob0usa
  • 20 Thanks
  • 27 posts
Posted March 08, 2015 - 06:54 PM
Many , many thanks to all!   after geting it out, and now i find out that my problems are with clutch bearings, ect.
so i decided best thing to do is order a manual from Mission Mfg,  as I'm now seeing that I may have to order parts from them!
as the bearning is gone, and no way to get numbers off it, and may need new new clutch pads also.
