Bolens Tiller set up
3 replies to this topic
#1 Tspeyfly OFFLINE
Tspeyfly
  • 9 Thanks
  • 16 posts
Posted March 02, 2015 - 03:26 PM
Hey Guys
Didn't take a picture when I stripped the tiller from my 1050 w/twelve hp Wisconsin to do some  carb and motor work.
Could someone post a picture or two of how the linkage is to be set up. The one I'm using is used for the blade and I'm not sure if that is the correct one.
Thanks,
Thomas Baker
#2 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted March 02, 2015 - 03:34 PM
The tiller had its own lift arm, the one for the blade is too short.
The longer one for the tiller usually is installed with the side with two holes near the lift lever and the slotted side at the tiller part.
Hope this helps.
  • Tspeyfly and Bolens800uk have said thanks
#3 Bolens800uk ONLINE
Bolens800uk
  • 1,804 Thanks
  • 1,196 posts
Posted March 02, 2015 - 04:53 PM
Here are several photos of my Bolens light weight tiller with the lift arm just visible.
  • Tspeyfly said thank you
#4 OldBuzzard ONLINE
OldBuzzard
  • 7,021 Thanks
  • 4,792 posts
Posted March 02, 2015 - 06:34 PM
Here's a pic of my G10 with a tiller mounted.
Note that the lift arm is attached to the BOTTOM of the lift lever. That way you pull to lift.
