Garden mark squire 12
7 replies to this topic
#1 Tl700 OFFLINE
Tl700
  • 3 Thanks
  • 2 posts
Posted March 02, 2015 - 11:31 AM
I have a 1967 12hp gil3340A. Garden mark by wards. I'm looking for a replacement Briggs and Stratton piston and I'm running into some problems. I believe the engine that is installed does not match the numbers on the housing. I ordered the piston for the engine model 300424 type 0121-01 and the piston I received is much smaller than the piston that came out of the engine. The new piston or (standard) is 3.43 in diameter and the old piston is 3.53. Every contact I have is telling me about the overs ie .010 .020 .030.
The size difference In these two Pistons is .10. I'm thinking that this is a higher powered engine that was placed in this particular tractor with the old housing and engine numbers. If anyone has any ideas as to a Briggs and Stratton piston that measures 3.53 with a part number it would be greatly appreciated or what engine size this could possibly be. Thanks in advance
  • Sawdust, Williampers and RobertOi have said thanks
#2 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted March 02, 2015 - 12:48 PM
Welcome to GTT. Checkout the Manuals Section for the B&S shop manuals. Good Luck, Rick
#3 tater195 ONLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted March 02, 2015 - 01:37 PM
without double checking the numbers, that sounds like a 16hp block.14-16's had bigger valves also
#4 tater195 ONLINE
tater195
  • 2,200 Thanks
  • 1,413 posts
Posted March 02, 2015 - 01:45 PM
This is the piston for the 14 - 16 hp engines. 3.5625 std bore
http://www.amazon.co...s/dp/B002WNUDOG
  • Sawdust said thank you
#5 Texas Deere and Horse ONLINE
  • 14,814 Thanks
  • 15,502 posts
Posted March 02, 2015 - 01:59 PM
Here is a chart that gives a lot of great info on the B&S engines including bore sizes.
http://gardentractor...ications-chart/
#6 Sawdust ONLINE
Sawdust
  • 5,678 Thanks
  • 3,381 posts
Posted March 02, 2015 - 02:04 PM
If your block has been bored you should see the number stamped on top of the piston. Example .10 .20
#7 KC9KAS OFFLINE
KC9KAS
  • 5,389 Thanks
  • 4,692 posts
Posted March 02, 2015 - 05:56 PM
:welcometogttalk:
#8 Tl700 OFFLINE
Tl700
  • 3 Thanks
  • 2 posts
Posted March 03, 2015 - 03:37 PM
Thanks for all the info on here kinda figured I could find what I needed from the forum. I will update on what I find. I was thinking what Tater stated it was a 14 or 16 hp engine. When I spoke with the B&S tech they said the bore size I have is 32 cubic inches not the 30 the original engine came with. I am going to get the piston for the 32 and see how it goes.
