Bolens 1050 shutting off
11 replies to this topic
#1 Shan69743 OFFLINE
Shan69743
  • 1 Thanks
  • 4 posts
Posted March 01, 2015 - 09:51 PM
Hellos everybody, I've been lurking for a while now. I got a bolens 1050 about 2 weeks ago it runs decent. Came with a plow so I've been using it for that. However I'm having issues with it running. I've been having to jump start it almost every time. And after it runs for a while anywhere from 15-90 mins it shuts off. Most times before it starts again I have to tap on the starter solenoid with a wrench. I'm thinking I need to replace that but is that would could be causing it to shut off? the battery seems to be holding a charge.
Also I am looking for the shifter cover plate it anybody has one of those laying around.
Thanks
Shane
#2 boyscout862 OFFLINE
  • 15260 Thanks
  • 10023 posts
Posted March 02, 2015 - 12:39 AM
Welcome to GTT. Checkout the Manuals Section. I would make sure that the gas cap is vented. You may be creating a vacuum in the gas tank. Good Luck, Rick
#3 oliver2655 OFFLINE
oliver2655
  • 37 Thanks
  • 82 posts
Posted March 02, 2015 - 01:17 AM
sounds like to me you could use a new solenoid. but that wont fix the tractor from dieing. my guess would be the coil. ive had coils that worked when cool but once the tractor got warmed up good the coil would lose spark.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted March 02, 2015 - 07:36 AM
:welcometogttalk:
#5 chieffan ONLINE
  • 16594 Thanks
  • 9088 posts
Posted March 02, 2015 - 08:15 AM
Welcome to the site.  I mentioned you was looking for a shifter cover plate?  do you mean the long plate that covers the transaxle forward under the back edge of the dash ?
#6 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted March 02, 2015 - 08:34 AM
Welcome to GTT!
Sounds like an electrical problem to me. Have you checked to see if you are losing spark when the machine shuts off? If you have an inline spark tester you can run the machine with it on and see if spark stops when the engine dies.
The solenoid will have nothing to do with the unit shutting off as it only acts as a starter switch when you turn the key.
With a dead battery every time it sounds like you have a problem somewhere in the electrical system, may want to download the manual and rewire the tractor back to factory specs.
#7 Shan69743 OFFLINE
Shan69743
  • 1 Thanks
  • 4 posts
Posted March 02, 2015 - 11:02 AM
no I need the bearing retainer plate located on the base of the shifter. if refering to a parts diagram I believe it is ref. no. 36 part number 1713455. (i'd have to check, thats just from memory)
#8 Shan69743 OFFLINE
Shan69743
  • 1 Thanks
  • 4 posts
Posted March 02, 2015 - 11:05 AM
Welcome to GTT!
i'll see if i can find an inline spark tester, i just printed off the wiring diagram this morning.  I'm planning on working on this over the next few days. i couldnt find how to test the starter generator to see if its charging the battery or not.
#9 KennyP ONLINE
  • 53158 Thanks
  • 53301 posts
Posted March 02, 2015 - 12:07 PM
Try this manual I just uploaded.
  • Bolens 1000 and Bruce Dorsi have said thanks
#10 Shan69743 OFFLINE
Shan69743
  • 1 Thanks
  • 4 posts
Posted March 02, 2015 - 12:44 PM
thanks downloading it now.
#11 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5122 Thanks
  • 2911 posts
Posted March 02, 2015 - 03:31 PM
As stated, the solenoid will not cause the engine to shut off.
However, if you need to replace your solenoid, be sure to get the correct style, as there were 2 different solenoids used on Bolens tractors.
http://gardentractor...identification/
  • Bolens 1000 said thank you
#12 KC9KAS OFFLINE
KC9KAS
  • 5535 Thanks
  • 4770 posts
Posted March 02, 2015 - 05:49 PM
:welcometogttalk:  Glad you found and joined us!
