Pics ht23
14 replies to this topic
#1 bolens4life OFFLINE
bolens4life
  • 73 Thanks
  • 56 posts
Posted March 01, 2015 - 07:49 PM
Hi guys
Thought I would post pics of my 23. I was down working on the blower as I've run out of room to push the snow. 6 inches on the ground tonight so will see how it works.
Anyway thought I'd share the love of my life....don't tell my wife :)
  • OldBuzzard, LPBolens, Texas Deere and Horse and 10 others have said thanks
#2 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 01, 2015 - 07:51 PM
That thing looks really nice. Power steering is awesome. It will do fine. I used the same blower for two years around my house. Let us know what you think of it.
  • blackjackjakexxix and boyscout862 have said thanks
#3 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted March 01, 2015 - 07:52 PM
Very nice,you should be proud of it
  • LPBolens, boyscout862 and bolens4life have said thanks
#4 Toolfoole OFFLINE
Toolfoole
  • 271 Thanks
  • 145 posts
Posted March 01, 2015 - 07:55 PM
Wow, sweet looking machine! :thumbs: I wish my 23 looked that clean... and had power steering... and cruise control... and was running... and... :(
  • blackjackjakexxix, boyscout862 and bolens4life have said thanks
#5 bolens4life OFFLINE
bolens4life
  • 73 Thanks
  • 56 posts
Posted March 01, 2015 - 07:56 PM
Husky, I used it once before but I was disappointed with the distance it threw the snow. I had the two stage so I know I'm spoiled but it lacked distance even for a single stage. At first I thought the engine Rpms were off but I threw a meter on it and spot on 3600. I believe that is exactly where it should be. My pto belts seem loose so I may try that next. I usually just have the angle plow on it so the pto gets little use.
I'm doing a complete redo on the blower is summer so rounding up parts as we speak.
  • OldBuzzard, blackjackjakexxix, boyscout862 and 1 other said thanks
#6 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted March 01, 2015 - 08:08 PM
Nice HT23 I been looking to get my hands on one for years.
  • boyscout862 and bolens4life have said thanks
#7 bolens4life OFFLINE
bolens4life
  • 73 Thanks
  • 56 posts
Posted March 01, 2015 - 08:11 PM
Thanks. Every time I get close to selling it, I just can't let it go...
#8 case442 OFFLINE
case442
  • 723 Thanks
  • 438 posts
Posted March 02, 2015 - 01:03 AM
Very nice HT23. Hope you get the blower sorted out.
#9 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted March 02, 2015 - 06:31 AM
Sweet HT23! I know that some of the JD folks have changed the chain drive gearing on the 49 single stage thrower to increase the speed by 10% or so. This will increase the throwing distance. With an HT23 you wouldn't need to worry about having the HP needed to run the higher gearing.
#10 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 02, 2015 - 07:28 AM
After you've made sure all the parts are spinning true and freely, the main point of concern on a blower's throwing distance is the tolerance between the paddles and the chute on a single stage, or the fan and the housing on a two stage. The slightest gap decreases performance.
Good luck with the test.
I sped up my single stage to the point of sacrificing speed. I cannot go nearly as fast as others, but I can throw anything at least thirty feet. 50-60' with cold, dry snow.
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted March 02, 2015 - 08:16 AM
Great looking HT23!
#12 bolens4life OFFLINE
bolens4life
  • 73 Thanks
  • 56 posts
Posted March 02, 2015 - 07:26 PM
Thanks everyone for the input and ideas. We got about 5 inches of fine cold snow. I also installed some hard rubber over the two paddles in the middle of the auger to take up what turned out to be almost a full inch gap from the wall of the chute to the paddle. Blower was throwing about 10-12 ft. I think that's pretty respectable. I don't know if it was the snow or the mod or both but I'm pretty happy.
Also picked up that 1886 that you might have seen on eBay. Curious what you all think. Two tillers, blade, machine and 2 driveshafts. Paid 1600. I might've overpaid but love the machines....what else can I say. Money is only something you need if you don't die today....
  • OldBuzzard, blackjackjakexxix and Rock farmer have said thanks
#13 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 02, 2015 - 09:18 PM
I'm sure it's got a different model # than mine does, (considering yours is on a HT 23 and mine came with a G152 import) but yours and my snowblower are identical. That 10 foot throw is what I got with mine when I first got it.
I replaced the bearings on both ends of the shaft, replaced the sprocket on the auger shaft with one a full inch smaller, and replaced the sprocket on the end of the shaft coming from the gearbox with one that barely fit inside that housing. I had to leave the back cover off because the chain would of hit it, and had to make a bigger one. I also welded in new pieces in the cups to close the gap, and balanced the auger by adding welds around the flighting.
I also replaced the chute with a home-made one, but kept the spout deflector.
With your 23 ponies vs. my 15 hp, yours could easily handle those upgrades and still perform top notch.
Bolens snowthrower 005.jpg Bolens snowthrower 010.jpg Bolens snowthrower 014.jpg Bolens snowthrower3.jpg test run 009.jpg test run 005.jpg
  • Alc, KennyP and Rock farmer have said thanks
#14 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 03, 2015 - 06:10 AM
As a package deal I don't think that you did too bad at @ 1,600.00.
There will be a couple of guys that will disagree, but then they think anything over $100.00 for and HT23 with FEL and Backhoe is too much  :bigrofl:
  • LPBolens, blackjackjakexxix and Rock farmer have said thanks
#15 KennyP ONLINE
  • 53159 Thanks
  • 53301 posts
Posted March 03, 2015 - 07:08 AM
Very nice looking HT23 you have there! Sounds like you are getting some ideas on how to improve the blower!
