2 stage snowblow
16 replies to this topic
#1 Deerlope ONLINE
Deerlope
  • 580 Thanks
  • 407 posts
Posted March 01, 2015 - 03:07 PM
I know there is a what fits what in here but it is more than a little difficult for me to understand. Could someone one please give me a model number for a 2 stage snow blower that would fit a 332 JD diesel. I have had this tractor with a mower deck for almost 20 years and all it does is mower a little grass each year. It has around 600 hours on it thus far. I had it a long before I got involved with the Bolens tractors and that I usually the forum that I hang out at. Thanking anyone in advance.
Edited by Deerlope, March 01, 2015 - 03:07 PM.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 01, 2015 - 04:34 PM
You're looking for a Model 47 snowblower. There are two different styles, however. The older style is a four bar linkage setup bolts onto the blower. The newer style is a quick hitch. If using the newer style hitch, you can get virtually any 47 snowblower from the 90's up to the one that came off the assembly line on Friday.
Pics of both styles, oldest first.
  • boyscout862 and Sawdust have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 01, 2015 - 04:46 PM
The quick hitch part number is BM18121.
  • Sawdust said thank you
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 01, 2015 - 05:27 PM
The 332 is a nice tractor. It will move a lot of snow with one of those 2 stage blowers on it. The quick hitch would also allow you to use a blade on the front if that is something you are interested in. Those blowers can be pretty pricey.
  • Trav1s said thank you
#5 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 01, 2015 - 06:21 PM
And would be very fuel efficient compared to say my 445 gas.I had a 55 gal drum for snow removal this winter and I only have 5 gal left.
OP,You will need a lot of rear weight to use one of those blowers especially if you are using it on hills.
#6 Deerlope ONLINE
Deerlope
  • 580 Thanks
  • 407 posts
Posted March 01, 2015 - 08:08 PM
Wow, I really appreciate the quick response. Now are any of those blower made by RAD technologies or are they strictly JD. I do like that later of the blower I like that QA, but I would probably never have a blade on it.
#7 Rock farmer OFFLINE
Rock farmer
  • 1,198 Thanks
  • 1,233 posts
Posted March 01, 2015 - 08:14 PM
I was helping my brother with his late model 47 today.
I expect it's John Deere "international sourced".
The gearbox for the auger said "made in Spain" on it.
Joe
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 01, 2015 - 08:35 PM
There are aftermarket blowers for the 318/332. I'll see if I can find that info.
The newest blowers use a plastic composite fan instead of metal. You can make your assumptions on how I feel about that.
#9 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted March 01, 2015 - 08:58 PM
I think Bercomac makes a blower that will fit: http://www.bercomac....for_Tractor.php
#10 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted March 02, 2015 - 06:34 AM
Bercomac makes a good blower and may actually be the contractor for a lot of the blowers out there for GT's.
#11 Trav1s ONLINE
Trav1s
  • 3,306 Thanks
  • 4,361 posts
Posted March 02, 2015 - 09:02 AM
Jim knows his GTs and is very knowledgable when it comes Bercomac stuff
http://www.jimsrepai.../snowblower.htm
Edited by Trav1s, March 02, 2015 - 09:07 AM.
#12 cumminsdeere87 OFFLINE
cumminsdeere87
  • 16 Thanks
  • 22 posts
Posted March 04, 2015 - 09:59 AM
I have a bercomac on my jd 322. I was looking for a 47 blower but gound my bercomac used dirt cheap. The bercomac actually throws snow further than the 47 but i think the 47 is made with thicker steel.
  • Cat385B said thank you
#13 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted March 04, 2015 - 06:11 PM
Do you happen to know the model # of the blower and subframe of that?
#14 M.Cain OFFLINE
M.Cain
  • 185 Thanks
  • 158 posts
Posted March 04, 2015 - 07:20 PM
Go with the Bercomac hell of a blower.
#15 cumminsdeere87 OFFLINE
cumminsdeere87
  • 16 Thanks
  • 22 posts
Posted March 04, 2015 - 07:32 PM
Tomorrow i will look at the numbers. And send them to you.
