Any info on H-1502
15 replies to this topic
#1 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted February 28, 2015 - 09:39 PM
Does anyone have information on an H-1502 Bolens Iseki tractor. The one I saw today had the external front PTO setup.
#2 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted February 28, 2015 - 09:52 PM
What info are you looking for?
#3 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted February 28, 2015 - 11:38 PM
The H1502 is the smallest of the imported Iseki tractors. It's 15 hp, with a hydro transmission. The front pto kit is manually engaged, it also serves as the mid pto. It is geared at 2000 rpm, at WOT.
  • Deerlope said thank you
#4 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted March 01, 2015 - 07:10 AM
That is about what infor I was looking for . Do you know about what year they first started to appear?
#5 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 01, 2015 - 07:21 AM
1985
In this pic, you can see the front pto kit. Notice the cable coming out and going to the engagement lever just aft of the exhaust stack. (click on pic to enlarge)
#6 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 01, 2015 - 07:52 AM
There is info here too.
http://www.tractorda...502-engine.html
It appears to have a 3 cylinder Mitsubishi diesel in it. That is a pretty small three cylinder engine.
Edited by Husky, March 01, 2015 - 09:36 AM.
#7 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 01, 2015 - 09:20 AM
Yep, but it's a smooth runner compared to my Mitsubishi 2 cylinder diesel of the same hp. But I think it probably uses more fuel to put out the same hp.  :thumbs:
#8 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted March 01, 2015 - 10:15 AM
I had one of these a few years ago,like stated above,very nice running,smooth,they are very heavy duty,I thought mine was really good on fuel,seemed like it ran for ever on a tank of fuel,parts can be a little tricky to find but are out there,the 2 speed rear pto was also nice,very smooth hydro,IMO for the size of tractor can't be beat
  • OldBuzzard said thank you
#9 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 01, 2015 - 10:54 AM
... It appears to have a 3 cylinder Mitsubishi diesel in it. That is a pretty small three cylinder engine.
According to my literature the engine is a K3A.  I have a K3D in the HDT1000, and I can attest to the fact that they are VERY smooth running.
I'm guessing that it has the same block and some other parts as the K3D which is rated at 22 or 23 HP, depending on whose source you use.
#10 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted March 01, 2015 - 11:38 AM
2 speed? I wonder when they went down, the earlier models had three speed pto's. Mine has 472, 752, and 1177 rpm speeds.
Once I've made a couple passes tilling, the high speed on the pto absolutely pulverizes dirt. Kinda freaky, actually.
#11 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted March 01, 2015 - 12:17 PM
It has 3 speed rear pto. 454-724-1185 rpm
Edited by ClassicBolens, March 01, 2015 - 12:18 PM.
  • Cat385B said thank you
#12 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 01, 2015 - 12:22 PM
If the engine is any good it would make a nice one for a large frame project or even a nice tube frame conversion.
#13 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted March 01, 2015 - 01:20 PM
Putting one in a tube frame would be danged near impossible without a HUGE amount of work and modifications.
The K3D really didn't even fit the in the HT23 chassis.  Bolens made an extension that supported the fuel tank and battery and used a longer hood in order to get it to work
  • Husky said thank you
#14 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted March 01, 2015 - 01:53 PM
Several years ago I serviced one that rolled down a fairly large hill upside down into the river. It sat in the water for 3 or 4 days before it was recovered. Got it into the shop, drained and changed all fluids and filters. Had to replace the battery, both rear wheels, and the steering wheel. Straightened the hood and fenders. Added fresh fuel and primed the system and it fired right up. Last I knew, that tractor is still running. They are tough.
#15 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted March 01, 2015 - 02:00 PM
Yah I guess a tube frame would be near impossible. Maybe the large frame would be an option. I see where they made the hood longer in your picture.
