Air compressor under load, how much is too much?
air compressor sandblasting
16 replies to this topic
#16 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted February 28, 2015 - 10:54 PM
Agree w/ cvans: continuous run is a lot easier on the motor and a fan will help the pump and just plugging the fan in is simpler than wiring it w/ the pressure switch. A fan won't use that much juice and won't care if the pump is running or not.
#17 cnsolutions OFFLINE
  • 5 Thanks
  • 15 posts
Posted April 09, 2015 - 06:34 PM
I smoked a 60 gallon compressor that had a 10 cfm @ 90 psi bead blasting so I upgraded to a 80 gallon with a 24 cfm @ 90 psi and have never had a problem after that I also put a refrigerated air drier in also. Whe I pull out the big sand blaster I use my ingersol 185 cfm tow behind.
Also tagged with one or more of these keywords: air compressor, sandblasting
