Bolens 1050 Repower With Honda GX390
63 replies to this topic
#46 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted April 05, 2015 - 06:31 PM
You can never have too many colors of wires laying around the shop.
Nice work, very clean install and great job with the pics. Very fun to follow along with.
  • 29 Chev said thank you
#47 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 05, 2015 - 06:39 PM
Thanks for the kind words - I hope when I am done the Honda will look almost as at home in the 1050 as the Wisconsin.
#48 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 06, 2015 - 08:37 PM
Set the battery in and did a test fit of the ground cable  - I use a small GM side post battery from Napa as I seem to get good life out of them for the money - the battery is a tight squeeze but it does fit.  Years ago someone added a push pull switch to deactivate the charging circuit - I assume it was to get a little more power out of the motor.  I decided to use it as a bypass switch - if the battery goes dead then the relay I am using to close the ignition circuit will not work so this switch can be used to close the ignition circuit and I should be able to pull start it with the recoil. I also used a few pieces of masking tape to temporarily hold the wires in place for when I tape them up if they pass the "magic smoke" test. Added a socket for the relay wires and got the grounds figured out - still have to hook up a positive cable.
  • Alc and WrenchinOnIt have said thanks
#49 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted April 07, 2015 - 09:20 AM
Wow!! I just ran across this thread now, and this is amazing. It looks super professional and factory grade.
That's a genius solution with the air filter mounted to the other side of the engine and a hose run across. I'm definitely subscribing to this thread to see the finished product.
#50 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 07, 2015 - 08:02 PM
Thanks for the kind words.  Got the positive cable installed - had to solder on a new eye with 1/4" hole for the solenoid stud.  Installed a 10 amp fuse and tried the lights and found out I had the ammeter wired backwards so I switched the wires.  The relay I got appears to be open on the primary coil so I will have to try and get another one tomorrow - thought I had another one that was ok but I tried it and lost a little "magic smoke" and popped the 10 amp fuse - turns out it had a direct short across the relay coil.  Tried out the starter and it turns the engine over which is a good sign.
  • WrenchinOnIt said thank you
#51 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 11, 2015 - 08:00 PM
Got another relay, installed it and checked with an ohm meter and it closes the ignition circuit when powered.  Next I got the throttle cable installed and hooked up - since it was way too long I pulled the inner wire out of it, cut the outer cable with a hack saw, slid the wire back in , cut the wire and bent the end of the wire to hook onto the throttle lever.  Had to bend the throttle handle on the lever up a bit as it was hitting on the cable - could have cut it off but bending it fixed the problem and I can bend it back if I ever use the engine in another project.
#52 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 11, 2015 - 08:21 PM
Been thinking about how I was going to hook up the choke for a few weeks and come up with this solution.  Mounted a pivot bracket and lever arm with several holes drilled in it I made out of some scrap steel on the outer carb stud and did some experimenting to see how it would work and how much power it would take to move the choke arm on the Honda (drilled three holes in the Honda choke arm).  Used a short piece of the inner wire left over from the throttle cable to go to a pivot arm to change the movement direction from across to an up and down motion.  Then I welded a few pieces of metal onto the air filter hose adaptor to serve as a pivot, hold the choke lever onto the carb and serve as a mount for the choke cable.  I also found out when I welded the 1/4"NPT fitting into the air filter hose adaptor that I damaged some of the threads so I had to remove it and weld another fitting in - kept the heat down this time. While the choke cable I was using on the Wisconsin was not anymore than long enough it appears it will work with the Honda so I am going to reuse it.
  • 4 New Fitting Welded In and Start Of Bracket to Hold Choke Lever In Place.jpg
#53 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 14, 2015 - 07:49 PM
Made a gasket for the air filter out of cork, used electrical tape to seal off the breather vent on the back of the air filter housing and mounted the air filter.  Added a clamp for the ignition wires to keep them away from the air cleaner.  Decided for now I would go with 1-1/4" sump pump hose to connect the air filter to the carb adaptor.  I tried the 1-1/4" conduit and it is kinda stiff to work with so I will have to experiment with it and see if I can shape it by heating it up.  Got the breather vent plumbed in but it sits up a little higher than I would like so I may get a brass 90 degree fitting and see if I can get it a little lower as I plan to make a cover to go over the carb to keep snow off it in the winter time so it does not turn to ice and freeze the throttle and the choke cable.
  • Cat385B and WrenchinOnIt have said thanks
#54 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 15, 2015 - 07:41 PM
Got some different fittings and redid the breather connection - it now sits a bit lower which I like.  Cleaned the tools and excess parts off the foot rests and seat, put some gas in the fuel tank and cranked it over to see if it would run and verify that the charging system was wired up correctly - started right up and charged about 10 amps for a few seconds then dropped back to near zero as indicated in the picture - nothing got hot and no magic smoke lost so I turned it off after a few minutes and taped up and clamped the wires.  I ran a 10 gauge wire from the right rear mounting bolt on the motor to the battery cable ground point which also has a ground wire from the relay and the voltage regulator hooked to it.
#55 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 18, 2015 - 05:29 PM
Decided I would hook up the tach / hour meter I had used on the Wisconsin - originally had decided to run the wires to the spark plug on top of the engine shield but rerouted them underneath part of it to protect them more.  Decided it was time to replace the foam tape around the dash that the hood sits on - picked up some new stuff last night, cleaned off the old tape using a razor blade to get rid of most of it and a bit of paint thinner to get rid of the gummy part, and ran two strips of the new tape, one beside the other, along the edge.
#56 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 18, 2015 - 05:35 PM
Then I applied a short piece of heat shrink over each terminal that plugs onto the ignition switch to protect them from shorting and put a short piece of black door edge moulding over the lip of the engine shield on the right side to protect the wires from rubbing against the edge.
#57 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 19, 2015 - 06:24 PM
Been working with the piece of conduit to shape it to fit across the front of the tractor - used a heat gun to warm it up and then wired it in the shape I wanted it for a few days using the sump pump hose as a pattern.  Got it fitting pretty good but it was touching on the right side of the hood so I made up a bracket that bolts to the right side hood hinge bolt and used a hose clamp to draw the conduit back a little but so it clears.  Then I started working on a shield for the carburetor using some cardboard to make the pattern for the top of the shield as it will be a snug fit where it will work around the side of the hood.
  • Husky, Alc and WrenchinOnIt have said thanks
#58 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted April 20, 2015 - 11:36 AM
I love watching your work.  I really like the idea of shrink tubing at the ignition switch terminals. Those things always end up getting loose or shorting out like you said. I may steal your idea of the conduit bending for wires. I'm working on my snow cab for a new tractor project. I want all the wires contained  neatly within the cab. As usual, you are doing some great work on your project.
#59 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 20, 2015 - 07:29 PM
Thanks for the kind words.  Worked away at the shield - used some 24 gauge body steel I had left over from another project.  Spot welded a 1/4" nut inside against the front hole to act as a spacer where it mounts against the throttle bracket - drilled the threads out of a nut with a 1/4" drill.  Added a bracket at the front of the shield to attach to the inner carb stud to give the shield a bit of support.  Bent the rear and inside lip up and bent the top so it is sloped to the outside and front so if ice, snow or rain lands on the shield it will flow towards the front or side and not drip onto the cylinder part of the motor (I hope).  Ground the welds down and gave it a final test fit.
  • Deerlope said thank you
#60 29 Chev ONLINE
29 Chev
    A Little Off Plumb
  • 22797 Thanks
  • 7538 posts
Posted April 20, 2015 - 07:53 PM
Gave the shield a paint job and after it dried bolted it on.  Found a piece of chrome door edge moulding I had lying around and put it along part of the edge of the hood in case it vibrated enough to rub against the shield and around the outer edge of the shield to get rid of the sharp edge.
