JD 425 Power Flow won't stay engaged
7 replies to this topic
#1 whitefishblues OFFLINE
whitefishblues
  • 50 Thanks
  • 43 posts
Posted February 27, 2015 - 12:47 AM
I've got a 1995 425 with a 54" deck and the Power Flow bagger.  The belt tensioner pulley won't stay engaged on the Power Flow.  When I first got the tractor (used, a couple years ago, and with about 600 hours on it) I would have to re-engage the pulley 2 or 3 times per load of grass.  This was in normal grass, not too tall or heavy.  The problem gradually became worse until I quit using it last year.  It is pretty much to the point where I engage the pulley, turn on the mower, mow a foot or two, and it pops out.
I tried a new belt last year but it didn't help.  Actually seemed to make it worse.
Has anyone else experienced this?  Any ideas?  I can see that the pulley is held in place by a post, and that the post is held in place by a rubber strap connected to the chute.  I have the instruction manual and I measured to make sure the rubber strap was installed at the right location.
I plan on taking it into the dealer next week unless someone can offer me some advice.  It would be most appreciated!
#2 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted February 27, 2015 - 12:53 PM
I've an OM - but just in german....
  • WNYTractorTinkerer and whitefishblues have said thanks
#3 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,191 Thanks
  • 5,667 posts
Posted February 27, 2015 - 02:02 PM
The engaging springs, strap or linkages must be getting worn or weak.  I'll take a flight over to Germany if JDR is going to look @ it for ya!   :D
Edited by WNYTractorTinkerer, February 27, 2015 - 02:03 PM.
  • jd.rasentrac and whitefishblues have said thanks
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted February 27, 2015 - 03:24 PM
I think, it's the second time you'll take a trip to GOG, Dave. May I brew a coffee?
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,191 Thanks
  • 5,667 posts
Posted February 27, 2015 - 03:40 PM
LOL  I stand corrected..  They are usually hooked on the Run circuit side..  Dumb mistake on my part!   :hitting_self_roller:
  • whitefishblues said thank you
#6 shorty ONLINE
shorty
  • 5,277 Thanks
  • 5,162 posts
Posted February 27, 2015 - 05:31 PM
In the second pic, it almost appears that on the top pulley the belt has a slight tweak to it. Almost like that pulley mount is out of place.
#7 whitefishblues OFFLINE
whitefishblues
  • 50 Thanks
  • 43 posts
Posted February 27, 2015 - 08:35 PM
That sounds promising.  Does anyone have a picture of what it should look like?
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted February 28, 2015 - 02:26 AM
Shorty is right- the pulleye isn't parallel to the other below and that must be the fault
