Need help installing voltmeter
20 replies to this topic
#16 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted February 27, 2015 - 03:26 PM
Hook both wires from the ammeter together on the (+) side of the volt meter and install a Ground wire and it will work perfectly.  No other rewiring is needed except the (-) side needs a wire to ground.  Simple..
Hooking up the voltmeter this way will cause the voltmeter to display ALL the time.   ......The original poster wanted the voltmeter to work only while the key was in the "ON" position.
#17 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,483 Thanks
  • 5,773 posts
Posted February 27, 2015 - 03:47 PM
My bad Bruce..  Should have looked where the ammeter was hooked to.  Usually on the Run side of the circuit..  Gotta stop drinking so much coffee! Never mind the poor advice!   :hitting_self_roller:
#18 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted February 27, 2015 - 05:27 PM
So splice the + side into the "L" wire a - to ground. Easy enough. Thanks
#19 grattone OFFLINE
grattone
  • 309 Thanks
  • 220 posts
Posted February 27, 2015 - 08:19 PM
I agree with CraftsmanGT  "L" is + with switch on, - goes to a good ground and amp meter wires splice together ( make that a good splice your charge circuit and most everything else goes through that connection. good luck
#20 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted February 28, 2015 - 02:50 PM
Well I got it wired up today. shows 13 volts with the key on, 14.5 volts idling, and 15/16 volts at full throttle
  • Bruce Dorsi said thank you
#21 CraftsmanGT OFFLINE
CraftsmanGT
  • 224 Thanks
  • 266 posts
Posted March 01, 2015 - 12:11 AM
Here it is. I'd like to put it in the dash at some point
