Gravely 16G with Kohler
9 replies to this topic
#1 Bianco OFFLINE
Bianco
  • 4 posts
Posted February 25, 2015 - 02:10 PM
Need help with why my Kohler has lots of gasoline in the oil, also the drain plug is frozen, I want to remove it maybe with a breaker bar?  By the way it runs with the gas in the crankcase.   Bianco
#2 Bolens 1000 ONLINE
  • 15,297 Thanks
  • 18,236 posts
Posted February 25, 2015 - 02:14 PM
Welcome to the Forum :wave:
Having gas get into the crank case is most likely caused by your carburetor needle valve not shutting properly and allowing it to overflow.
I would not recommend running the machine until you get this issue resolved as the oil gets thinned out by the gas and will eventually lead to major problems internally.
What model engine is this?
Lots of knowledgeable guys here that should be able to get you on track.
#3 Bianco OFFLINE
Bianco
  • 4 posts
Posted February 25, 2015 - 02:19 PM
Thanks, that sounds cheaper than rings or a disassembly.  Not sure of model, I have to clean the tag, but did that once and all the print came off too.   Bianco  (on a different engine)
#4 glgrumpy ONLINE
  • 8,742 Thanks
  • 7,978 posts
Posted February 25, 2015 - 02:36 PM
If you have a mechanical fuel pump below carb, Probly do, sometimes the diaghragm in those can get hole in them, and gas flowing thru it also leaks into case then, thinning oil. Harder to find pumps now and some places have kits, but not many.
  • boyscout862 and Bianco have said thanks
#5 Cat385B ONLINE
    HAZMAT CAT
  • 14,270 Thanks
  • 10,114 posts
Posted February 25, 2015 - 02:37 PM
Should be a Kohler Magnum 16 twin cylinder.
Change the oil before you run it again, you can mess that engine up fast running it with thinned out oil.
  • Bolens 1000, boyscout862 and Bianco have said thanks
#6 Bianco OFFLINE
Bianco
  • 4 posts
#7 Bianco OFFLINE
Bianco
  • 4 posts
Posted February 25, 2015 - 02:43 PM
Just checked my Kohler 16hp twin cyl.   Started right up,  Looks like the pump is beside the carb.   I'm going to remove/rebuild.
Bianco
#8 case442 ONLINE
case442
  • 694 Thanks
  • 424 posts
Posted February 25, 2015 - 04:36 PM
A good backup to this issue be would be an in line fuel shut off. A lot of the cub cadets had the tank above the carb and thy will leak down.
Mike
#9 dodge trucker ONLINE
dodge trucker
  • 2,695 Thanks
  • 3,348 posts
Posted February 25, 2015 - 06:07 PM
There is a guy selling a much better replacement fuel pump for these right now on Ebay. It is an ACDelco, he has a bunch, $49.99 which is cheaper than some of the used fuel pumps I've seen for sale. I just put one on mine. It is an all metal pump.
  • JDBrian and Genem have said thanks
#10 Gabriel OFFLINE
Gabriel
  • 1,446 Thanks
  • 1,859 posts
Posted February 26, 2015 - 10:09 AM
Welcome to GTTalk!
