Hydro cooling fan
8 replies to this topic
#1 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 149 posts
Posted February 23, 2015 - 05:05 PM
Well I finally found a cooling fan for my ff18.the factory fan was gone.it took me the afternoon but got it done .the replacement was from a ford but worked well with a few tweaks.the set screw on the the key way went back as removed but the other set screw was replaced with a 3/4 inch bolt with a rubber spacer between the fan and the shaft.it snugged it down nice and tight.works like a champ.
  • KennyP and Bill 76 have said thanks
#2 glgrumpy ONLINE
  • 8,603 Thanks
  • 7,908 posts
Posted February 23, 2015 - 05:38 PM
I've often wondered if those fans are really all that neccessary?  Seems they are built so cheap, have seen many with blades half or all the way broken off and been for long time, and no running issues all that time. I kinda think they were an afterthought and just some sort of insurance for tractor to last the warranty time, etc.  What's others thoughts on this??
#3 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 149 posts
Posted February 23, 2015 - 05:52 PM
i thought about that too but i figured that it must be there for a reason.dont know how long this one was missing but i plan on working it all summer if it ever comes. don't want to cook a hydro on these because parts are hard to come by and $$$$$.
#4 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted February 23, 2015 - 05:57 PM
Tom, glad you got one on there! Tom, does the FF18 have a cooler on it like the FF20-24's do?
Grumpy, I've often wondered how much good they do, but you are supposed to run a hydro at half throttle or more. So that fan is spinning at 2000+ RPM's. Has to move some air around the charge pump and hydro, thus cooling it some.
EDIT: Just pulled up the manual and it does have the cooler (or supposed to).
Edited by KennyP, February 23, 2015 - 06:00 PM.
Added Comment
  • Bill 76 said thank you
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 23, 2015 - 06:59 PM
Yes, the fans are necessary.  Pressure makes heat, and heat causes seals to burn up.  Or, worst yet, the high heat will break down the oil and causes it to cavitate the metal internally.
I've seen many zero turns run without their hydro fans... until one of those two things happens.
Ben W.
  • Bolens 1000, KennyP and Bill 76 have said thanks
#6 KC9KAS ONLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 23, 2015 - 07:18 PM
I had a newer Simplicity (hydro) riding mower. I didn't know it but the fins on the fan broke off, and you guessed it, it quit moving back & forth!
Edited by KC9KAS, February 23, 2015 - 07:19 PM.
  • superaben said thank you
#7 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 149 posts
Posted February 23, 2015 - 08:38 PM
yes it does have the cooler up front but the more the merrier in my opinion.
#8 Tomwendt OFFLINE
Tomwendt
  • 137 Thanks
  • 149 posts
Posted February 23, 2015 - 08:43 PM
i think the cooler up front cools the fluid itself but the fan cools the hydro unit in the rear in my opinion.
#9 KennyP OFFLINE
  • 38,196 Thanks
  • 45,842 posts
Posted February 23, 2015 - 08:50 PM
I think you're right there!
