Wanted
MF 14/16 tiller lift arm/belly pan
6 replies to this topic
#1 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,792 posts
Posted February 22, 2015 - 09:04 PM
ISO lift arm and belly pan needed to mount my tiller on my Massey 16. Any out there without the tiller?
Eric
#2 MH81 OFFLINE
Posted February 22, 2015 - 09:35 PM
If you run into an abundance of these, let me know :D
  • IamSherwood and dropped82 have said thanks
#3 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,792 posts
Posted February 22, 2015 - 10:07 PM
Ha...that is never the answer I want to hear. If no parts, can someone post pics and measurements to make them?
Eric
#4 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 23, 2015 - 03:39 AM
lift arms
Pan, I can measure this afternoon.
Edited by IamSherwood, February 23, 2015 - 03:48 AM.
  • MH81 and dropped82 have said thanks
#5 IamSherwood OFFLINE
  • 8,390 Thanks
Posted February 23, 2015 - 03:48 PM
Pan
Part #38 is missing from mine.
  • DH1, MH81 and dropped82 have said thanks
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted February 23, 2015 - 04:14 PM
I've often thought of using an arm or something like it for a sleeve hitch for the 14/16 tractors. A Sears or Bush Hog sleeve hitch fits the rear axles 2 mounting points,
Weld on a vertical bar to one side of the hitch, hook that to the tiller lift arm shown and it might work.
  • dropped82 said thank you
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,792 posts
Posted February 25, 2015 - 12:34 AM
Will, those are great. I actually picked up another 16. I now finally have a tractor just for the tiller to stay on. My other 16 has a 3 point and the 14 I got from Gabriel is still in pieces. This should help a bunch. Seems the belly pan could be made with a sheet metal break. I have a 1/2" thick lift arm I use on my Case' for the sleeve hitch that looks awfully close to the same specs as the massey one. Let's hope so. Save some work.
Eric
