I have 2 Kohler K series gas tanks that have some pinholes on the bottom that I am going to try and repair over the next couple of days....Guy at the the machine shop at work recommended this interior sealer. Its called Barbee Tank-coat.....it cost about $40 for the quart....better work...lol
I have one of the tank soaking in a Muractic Acid/water mix since last night to get rid of the scale and rust inside......Will rinse it out and dry it today. Instructions say it has to absolutely dry to stick. Going to put it under a heat lamp to completely dry it today and will put the coating in tomorrow.....Will update when I get further alone.
Anyone ever tried this stuff?.....
I would have tried to find a plastic tank to use, but getting one the right shape and size for my LGT Fords is near impossible.
Leaky gas tank
Started by
poncho62
, Mar 10, 2011 06:58 AM
1 reply to this topic
#1
OFFLINE
Posted March 10, 2011 - 06:58 AM
#2
OFFLINE
Posted March 10, 2011 - 07:03 AM
Not heard of that particular brand, but have had good luck with the liquid tank sealers. I've used POR-15's gas tank sealer on many small engine tanks with excellent results. Other folks have had good luck with a product called Kream[sp?] Follow directions carefully and I think you will be fine.
P.
P.
Edited by powerking56, March 10, 2011 - 07:04 AM.
spelling...
