Ariens 724 snowblower
4 replies to this topic
#1 tom tractor OFFLINE
tom tractor
  • 270 Thanks
  • 245 posts
Posted February 22, 2015 - 10:28 AM
I have a Ariens snowblower 724 from probably the 1980's.  With a model 7 HP Engine (75) Tecumseh HSK70-130210K.  The problem is the motor stalls under stress.  Runs for a shot time and then stalls again maybe about 20 seconds later.   The checked the gas cap which has good air flow.  The bowl of the carb. is clean.  It has fresh gas 93 octane with seafoam.
Any suggestions for fixing the problem?  Carb rebuild? Suggestions.
#2 Cat385B ONLINE
    HAZMAT CAT
  • 14,366 Thanks
  • 10,136 posts
Posted February 22, 2015 - 10:53 AM
Check the plug wire where it disappears under the tin, it rubs the wire down and creates a different problem each time.
I would also pull the whole fuel line off and check it.
#3 tom tractor OFFLINE
tom tractor
  • 270 Thanks
  • 245 posts
Posted February 22, 2015 - 11:29 AM
Do you believe the plug wire is shorting out?
When the motor starts to stall - if I eliminate the load the motor sometimes runs fine. Until a few seconds from then when it stalls.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,366 Thanks
  • 10,136 posts
Posted February 22, 2015 - 02:22 PM
Probably not, but it can be an issue on these.
#5 dodge trucker ONLINE
dodge trucker
  • 2,805 Thanks
  • 3,438 posts
Posted February 22, 2015 - 02:27 PM
what are you saying can be an issue?
It could be just a matter of opening the high speed carb adjustment a bit.
