AUGGHHHHH! FROZEN WATER LINE
19 replies to this topic
#16 chieffan ONLINE
  • 11,368 Thanks
  • 7,116 posts
Posted February 21, 2015 - 09:05 PM
If you do run another service line from your cistern into the house, run your service line inside a larger line along with heat tape.  Cover it with a good layer of snow.  The heat tape will keep the line open as well as the air around the service line above the freezing point and you should be OK.  A 3" solid drain tile would be about right, not the perforated kind.  Don't want any melting snow water to get inside.
Edited by chieffan, February 21, 2015 - 09:06 PM.
  • farmer john and oldedeeres have said thanks
#17 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted February 21, 2015 - 09:53 PM
Is the water line in the concrete slab under the living space of the house? Or the garage slab?
#18 farmer john OFFLINE
farmer john
  • 1,833 Thanks
  • 925 posts
Posted February 22, 2015 - 07:19 AM
garage slab,
#19 IamSherwood OFFLINE
  • 8,395 Thanks
Posted February 22, 2015 - 08:24 AM
Just an example.
http://www.ebay.com/...m-/261613131409
I'm sure you could find something like this at Cabela's. Coleman makes one.
With some stiff plastic tube, you could jet it.
It'd be handy for future power outages.
#20 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,089 Thanks
  • 590 posts
Posted February 22, 2015 - 08:57 AM
I would try to heat that garage up very warm some how. With bullet heaters or something like that. The concrete will soak up the heat after a while just like it soaked in the cold. Concrete has excellent temp transfer. Good luck. Tom
  • MH81 and EricR have said thanks
