Allis 416 Shuttle ?'s
ac416 shuttle ac416 w/eaton/peerless hydro
9 replies to this topic
#1 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted February 21, 2015 - 03:51 PM
I know! I spend too much time thinking! BUT! I have 2 416 Shuttles. I also have the remains of a Ford LGT165 with the hydro. Wondering if it would be feasible to install that hydro into the 416? I have the frame mounts on the Ford frame for the hydro. I could adapt them into the Allis frame. The donor also has a lift cylinder and valve still attached! HMMMMMMM? What do you all think?
#2 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1524 Thanks
  • 1913 posts
Posted February 21, 2015 - 04:13 PM
since you're a good metal fabricator i'm sure you could do it. why not just put the ol ac b series gear drive without variable speed in them?
#3 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted February 21, 2015 - 04:50 PM
Cause I don't have one of them! I'm thinking hydro to give me hydro lift!
#4 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted February 21, 2015 - 05:08 PM
Nah! Buy another tractor with items you want on it!  Bigger or newer seems to be needed here!
#5 OldAllis52 OFFLINE
OldAllis52
  • 275 Thanks
  • 160 posts
Posted February 21, 2015 - 08:07 PM
Sounds like a good project.
#6 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted February 22, 2015 - 06:29 AM
Both the shuttles work real good, just a passing thought. I am going to have the fender pan off one this Spring, might look into this a bit further then. Hard part is making the drive shaft for it. The AC has 2 bolt ends on it. The Ford is 3 bolt. I do have the Ford drive shaft. I'm thinking it would need to be a little longer as the engine in the 416 is further forward than the Ford.
At least you folks aren't yelling at me for suggesting it!
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted February 22, 2015 - 06:49 AM
Kenny you just need some SNOW to keep you busy.
#8 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted February 22, 2015 - 07:10 AM
Hush! Don't be throwing that four letter word around these parts!
Supposed to get some today! :(  YUK!
  • crittersf1 said thank you
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted February 22, 2015 - 07:25 AM
It'll keep your hands and mind busy!
#10 KennyP ONLINE
  • 52537 Thanks
  • 53102 posts
Posted February 22, 2015 - 07:31 AM
You are coming close to 'spam' here! Watch out!
