Wanted
Carb Part
8 replies to this topic
#1 Traill95 ONLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 20, 2015 - 02:53 PM
This is the Carb on my 12hp Simplicity Landlord. Upon close inspection you will notice a piece missing. It is the end cover on the carb and it apparently fell off while clearing snow a couple of weeks ago.  The diameter is 1 3/4 inches. Does anyone know of someone on here that might have that part? It's a Briggs engine. I could find no identifying marks on the carb.
Edited by Traill95, February 20, 2015 - 02:54 PM.
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 20, 2015 - 03:09 PM
That is called a Welsh plug
What model engine is that? Ben may be able to ID it for you without needing a model when he reads this
There are a few different plugs that were used.
  • Traill95, boyscout862 and superaben have said thanks
#3 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted February 20, 2015 - 03:39 PM
My dad has same motor/carb on his Allis. He went to auto store, got an expansion freeze out plug the you tightened with a wrench, ran it for years. I think it's till in the carb stored in the barn.
  • Traill95 and Genem have said thanks
#4 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted February 20, 2015 - 03:54 PM
You can get these welch plugs for a few dollars. just get your part number and theyre real easy to find
  • superaben said thank you
#5 Billy M ONLINE
Billy M
  • 668 Thanks
  • 547 posts
Posted February 20, 2015 - 03:59 PM
I had that happen once on a smaller carb.  I found a metal disc that fit perfectly, put it in the groove at the end, and pinged around the edges with a punch to seal it up.  It worked great!
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 20, 2015 - 05:55 PM
That welch plug is a 221747, and I have it in stock for $2.50.  It would also come as part of the carb kit if you need all that.
Brian is right, there were four different sizes of welch plugs used.  This is the biggest one for the large four bolt Flo-Jet, then there is the one for the large one piece Flo-Jet, then there is the one for the small one piece Flo-Jet, and finally the one for the small four bolt Flo-Jet.
Ben W.
  • Bolens 1000, boyscout862 and Sawdust have said thanks
#7 dodge trucker ONLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted February 20, 2015 - 06:49 PM
look in the freeze plug drawers of an old Mom and Pop auto parts stores.  they did sell freeze plugs like that without the "lip"
The one you need looks like the one used in back of the block behind the rearmost cam bearing of most older inline 6s and V8s.
#8 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted February 20, 2015 - 07:03 PM
For $2.50 wouldnt you rather use an OEM part? :poke:
#9 dodge trucker ONLINE
dodge trucker
  • 2,432 Thanks
  • 3,122 posts
Posted February 20, 2015 - 07:14 PM
what you'd get in the old Dorman cabinet probably IS the exact same as the OEM part.... I'm sure B&S probably sourced that sort of part as they did with most of their hardware....
Also tagged with one or more of these keywords: Wanted
