Front end loader
2 replies to this topic
#1 LSCHRIDER OFFLINE
LSCHRIDER
  • 1 posts
Posted March 09, 2011 - 02:59 PM
Does anyone know if the hydralic fluid equals out in each resevoir or does each one need to be filled. The fill hole where the control valve covers the plug and I thought the tube underneath may equalize the fluid.
  • 14,814 Thanks
  • 15,501 posts
Posted March 09, 2011 - 03:09 PM
If you have a tube or hose going to the other side and both reservoir's are vented, then yes they will find a common level. Make sure you vents are not pugged with dirt and/or oil.
  • LSCHRIDER said thank you
#3 Alc ONLINE
  • 6,905 Thanks
  • 7,468 posts
Posted March 09, 2011 - 07:47 PM
If your loader looks like mine your correct that both side equalize across the lower connecting tube , but like texas deere and horse make sure the vents are clear. On mine holes are drilled in the fill plugsDSC07231.jpg
