LOADER FOR TRACTOR
5 replies to this topic
#1 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted February 19, 2015 - 08:17 AM
Why is it that ones like this come up a couple of times a year for a similar price but ones for the GTs are fewer and many times as expensive? My father bought that exact same loader on a brand new Ford 800 in 1955. He also got a Sherman backhoe on it. Good Luck, Rick
http://newlondon.cra...4894160655.html
  LOADER FOR TRACTOR
00S0S_dkAWpybccRu_50x50c.jpg01414_awSTFAVRXm0_50x50c.jpg00x0x_iE6iy37tdBK_50x50c.jpg00R0R_5eBuriNiE3n_50x50c.jpg00K0K_jqathMu4ZC3_50x50c.jpg
WAGNER LOADER FOR FORD AND OTHER FARM TRACTORS. COMPLETE, SOLID UNIT. DOES NOT INCLUDE PUMP THAT IS AVAILABLE SEPERATLY. $300.00 OBO 631-332-0691
  • Oldford said thank you
#2 Traill95 OFFLINE
Traill95
    Traill95
  • 1,848 Thanks
  • 1,013 posts
Posted February 19, 2015 - 09:15 AM
Would that be a good price to buy and have all the Hydraulics and enough steel to downsize it for a GT?
#3 boyscout862 ONLINE
  • 12,852 Thanks
  • 9,172 posts
Posted February 19, 2015 - 09:35 AM
I think the cylinders would be too big. The hydraulics should always be weaker than the frame. Good Luck, Rick
#4 glgrumpy OFFLINE
  • 8,610 Thanks
  • 7,920 posts
Posted February 19, 2015 - 06:12 PM
Well tube loaders on Fords were usually not that strong and got bent alot. This one seems to have been beefed up some. Interesting big ARC of metal in middle that the cylinders push on. AND, most were trip buckets, this one is not. They are quite narrow and won't fit many tractors I bet, because of that.  Last but not least......it's UGLY!  and I bet weighs a ton.
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted February 19, 2015 - 06:22 PM
I doubt if it is worth your time to make it lighter.  You will need a good bit of flow to tackle those cylinders, too, and a large reservoir to handle the oil when they are retracted.
Ben W.
#6 Cvans ONLINE
  • 6,648 Thanks
  • 6,129 posts
Posted February 19, 2015 - 11:07 PM
You would hate yourself by the time you converted that to fit a GT
