Edited by Sawdust, February 19, 2015 - 08:51 PM.
MF14 or MF16 muffler options.
#16
OFFLINE
Posted February 19, 2015 - 08:50 PM
#17
OFFLINE
Posted March 22, 2015 - 03:39 PM
I figured I'd try to make the standard reverse flow muffler something like these.
Mine only has 2 tubes inside the short one that that connects one end to the other I don't have.
Started with a piece of 4" pipe, some 1-1/8" thin wall pipe and some pipe fittings.
Also 4 standard round metal electrical box covers.
Cut all the parts to length and drilled many holes, the 2 round plates with the 2 big holes in them also have 2 smaller 3/4" holes in the them, these let the exhaust go from 1 end to the other inside the muffler.
The inside part is show backwards, rotate 180 deg and it's right. (bottom to top)
All put together and welded.
Installed in the tractor, covers and heat shields in place.
Sound test.
This now makes the tractor mobile and usable again.
- olcowhand, limebuzz, Texas Deere and Horse and 1 other said thanks
#18
OFFLINE
Posted March 22, 2015 - 04:38 PM
Nicely done Doug.
Does it sound good?
- DH1 said thank you
#19
OFFLINE
Posted March 22, 2015 - 04:48 PM
#20
OFFLINE
Posted March 22, 2015 - 05:47 PM
Nicely done Doug.
Does it sound good?
Video now in first post
- Sawdust said thank you
#21
ONLINE
Posted March 22, 2015 - 06:24 PM
What size are the holes in the inner tubes?
#22
OFFLINE
Posted March 22, 2015 - 07:55 PM
The tube that comes from the engine 1/8"
The tube that leaves the muffler 1/4"
- KennyP said thank you
#23
OFFLINE
Posted March 22, 2015 - 09:52 PM
Great job Doug, really looks good. Should last a long time.
#24
OFFLINE
Posted March 23, 2015 - 09:05 AM
- DH1 and IamSherwood have said thanks
#25
OFFLINE
Posted March 23, 2015 - 09:58 AM
Sounds good Doug & well thought out. I liked the puff of smoke throttling up...let's you know she's a little tired but healthy. Thanks for sharing.
Also lets you know it's running, just in case you've hit the mute button by mistake.
- HowardsMF155 and Sawdust have said thanks
#26
OFFLINE
Posted April 01, 2015 - 12:24 AM
Timely topic since my 14 may need a replacement muffler. Thanks
