I need guidance
bolens gt 2000
26 replies to this topic
#16 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 17, 2015 - 08:58 PM
Your going to like that tractor,very smooth running and very nice driving,,if you have a real uneven lawn you may have a problem getting a nice cut with the 60" deck,start watching for a 48" deck in that case
#17 glgrumpy OFFLINE
  • 9122 Thanks
  • 8205 posts
Posted February 17, 2015 - 09:41 PM
Oh, yeah! I could go for that model!!  Duratrac now in back of mind. Those still Bolen's or MTD?   Right colors, hydro, dual ports. What hitch is on it or those?
#18 Gabriel OFFLINE
Gabriel
  • 1454 Thanks
  • 1868 posts
Posted February 17, 2015 - 10:49 PM
Welcome! :wave:
#19 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted February 17, 2015 - 11:50 PM
There a true Bolens,made before the MTD junk
#20 MH81 OFFLINE
  • 30055 Thanks
  • 29761 posts
Posted February 18, 2015 - 07:26 AM
Nice unit, thanks or sharing the pictures.
These guys have you covered info, parts, manuals. Everything a new Bolens owner could hope for. :D
:welcometogttalk:
#21 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4257 Thanks
  • 5840 posts
Posted February 18, 2015 - 08:19 AM
:welcometogttalk:
#22 My First OFFLINE
My First
  • 11 Thanks
  • 7 posts
Posted April 06, 2015 - 01:53 PM
I need some more advice. It looks like I am low of hydraulic fluid. Can someone recommend what I should get, brand and description would be great?. I have a Tractor Supply Co. near me if you have purchased something there.
#23 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted April 06, 2015 - 04:39 PM
That tractor has the Eaton 11 hydro and uses standard transmission/hydraulic fluid.
The bottom half of this page shows the 'approved' oils.  You can use the TSC equivalent with no problem.
Edited by OldBuzzard, April 06, 2015 - 04:40 PM.
#24 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted April 06, 2015 - 05:54 PM
The top half of OldBuzzard's page gives footnotes from the various model spec's shown on preceding pages.  The GT 2000 has transmission letter codes EN, which stands for TranslHydro Fluid-- 8 qt's.  Oddly enough, the XL series (with Eaton 11's) have the letter code of CN, which stands for ATF Type F-- 8 qt's and the QT series (also with Eaton 11's, as well as Sundstrand 15's) have the letter code CP for ATF Type F-- 10 qt's.  I saw another, don't remember which model, that had a YN for SAE20 Motor/Hydro Oil-- 8 qt's.  I wonder why they kept switching fluids for the same transmissions?
Edited by Paulgo, April 06, 2015 - 06:04 PM.
#25 My First OFFLINE
My First
  • 11 Thanks
  • 7 posts
Posted April 07, 2015 - 04:21 PM
Ok I'm a little confused now. Do I use type F transmission fluid or do I need to look for a transmission code on the tractor?
#26 Paulgo OFFLINE
Paulgo
  • 761 Thanks
  • 483 posts
Posted April 07, 2015 - 05:17 PM
I thought you had a GT 2000?  My post agreed with Old Buzzard about that tractor using regular tractor trans/hydraulic fluid.  TSC has the Mystik JT-5 and Traveler Universal trans/hydro fluid.  One is expensive and the other is so cheap you have to wonder if it has much in the way of additives.  The catalog is confusing as it also says ATF Type F is fine too.  That is what I use, but I am way up north where it doesn't get very warm.  I also recommend the Napa 1410, or equivalent, hydro filter.  Should match up to what is on yours now.  Better check, as I don't have your model tractor.  Paul :)
Edited by Paulgo, April 07, 2015 - 05:25 PM.
#27 My First OFFLINE
My First
  • 11 Thanks
  • 7 posts
Posted April 07, 2015 - 10:39 PM
Ah I understand now. Thanks. I'll check the model number to make sure. If both are acceptable I will use the trans hydro since I'm in Virginia and it gets pretty hot here in summer.
