Hydraulic Fluid Recommendation
13 replies to this topic
#1 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted February 17, 2015 - 06:48 AM
I'm going change the hydraulic fluid  on my Power King , spring time or sooner . The last time I just used  AW32 from TS , I might try something a little thinner because this year using it low temps took a long time to warm up and maybe not the best thing  to be using  thought I would see what others are using .  Gear pump only controls hydraulic cylinders .   Thanks Al
#2 MH81 OFFLINE
Posted February 17, 2015 - 07:25 AM
What are the recommendations from PK on these Al?
#3 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 17, 2015 - 11:02 AM
An AW15 or ATF be the next step thinner than AW32
  • MH81, Alc and IamSherwood have said thanks
#4 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted February 17, 2015 - 11:41 AM
The manual says " Fimite #150 API 28.8 Viscosity "   , but I have no clue what that means lol
#5 3v0 OFFLINE
3v0
  • 117 Thanks
  • 103 posts
Posted February 17, 2015 - 12:45 PM
I wonder if I am the only one who wishes all hydraulic fluid was dyed like hy-tran?
#6 MH81 OFFLINE
Posted February 17, 2015 - 01:05 PM
Yeah, not exactly helpful, is it?
I know on the Pacers and Ponys, we ran 10w oil. It's what they called for.
#7 welder12556 OFFLINE
welder12556
  • 2 Thanks
  • 3 posts
Posted February 17, 2015 - 02:10 PM
I believe John Deere "Lo-Vis" fluid should give you the performance you are looking for.
#8 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 17, 2015 - 05:56 PM
Well, I had a couple of sites saved on my "desk-top" that had SAE, viscosity, and other very helpful info, but my wife cleaned up this computer and saved everything in 1 place......I found the info, but ti won't open...damn the bad luck!
#9 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 17, 2015 - 06:14 PM
ISO and AW is the same and compaired to SAE.
Viscosity at 100°C Viscosity at 40°C   Motor oils and hydraulic oils ISO grade SAE grade range (cST) ISO grade range 5 3.80-* 32 28.8-35.2 10 4.10-* 46 41.4-50.6 20 5.60-9.29 68 61.2-74.8 30 9.30-12.49 100 90.0-110 40 12.50-16.29 150 135-165 50 16.30-21.89 220 198-242 60 21.90-26.09 320 288-352 80 7.0-11.00 460 414-506 90 13.50-23.99 680 612-748 140 24.00-40.99 1000 900-1100 250 41.00-UP 1500 1350-1650
wow that really got messed up.
Edited by KC9KAS, February 17, 2015 - 06:15 PM.
#10 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted February 17, 2015 - 06:18 PM
If this is the reccomendation, AW32 is the correct fluid to use.
The 32 falls in the range of 28.8-35.2 viscosity.
#11 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted February 17, 2015 - 08:05 PM
Would that make 10w just slightly thinner then the AW32 ? And is it worth changing to that weight?
#12 MH81 OFFLINE
Posted February 17, 2015 - 08:19 PM
It looks like the 10w oil in that chart runs from 20-30 viscosity.
If oil wasn't so expensive, it might be worth a try.
I would probably try, but only after doing a little more research.
I don't think you want to go to thin. You won't have the lift.
#13 TUDOR OFFLINE
TUDOR
  • 563 Thanks
  • 506 posts
Posted February 19, 2015 - 04:54 AM
I've been running with Dexron in my loader hydraulics for well over 2000 hours. It only takes a few minutes to get up to speed at -30° F after cycling all cylinders full stroke 3 or 4 times to make a bit of heat. At -10°, I only cycle them twice for the same effect, and I always cycle them at least once when the temp is below freezing.
  • ducky and Alc have said thanks
#14 TUDOR OFFLINE
TUDOR
  • 563 Thanks
  • 506 posts
Posted February 20, 2015 - 07:23 AM
I forgot to mention that the first cycle is always s-l-o-w. The second cycle is much quicker. The engine is at less than half throttle during this exercise. You make a judgement call for how much speed you are willing to live with on your first couple of lifts as to how many times to exercise the cylinders.
