Almost gave up
8 replies to this topic
#1 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted March 08, 2011 - 08:27 PM
Have an old Sears leaf blower and one that was given to me that won't stay running but was keeping it for parts. Mine started running funny then not at all , seemed like fuel problem ,run a little if I put gas down the carb. Got a carb. kit and when I went to take it off it seemed loose , naw , mounting bolts were tight , engine must be mounted in rubber but checked the other blower and was the same , Anyway the carb kit didn't help and I was ready to throw both out , but thought I wanted to take apart , just to see if a case seal or case it's self was bad . Turns out that BOTH leave blowers had loose cylinder to case mounting bolts , that's why the carb seems so loose.:bounce: Tightened the screws and started right up !!!!
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted March 08, 2011 - 08:34 PM
Wonder how many of them ended up in the junk for that problem? Good save.
#3 Alc ONLINE
  • 7,246 Thanks
  • 7,589 posts
Posted March 08, 2011 - 08:39 PM
Funny there are only 2 allen bolts holding the cylinder to the case !!!! I would have guessed 4.
#4 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted March 08, 2011 - 08:42 PM
I can't believe there are only two bolts holding the cylinder the the crank case. I can only imagine like Alan said how many were tossed out over the years for that exact problem. It is a good thing you were persistent with it :D :thumbs:
#5 Bolens 1000 ONLINE
  • 15,432 Thanks
  • 18,284 posts
Posted March 08, 2011 - 09:40 PM
Glad to hear you found the solution to the problem
#6 caseguy OFFLINE
  • 1,629 Thanks
Posted March 08, 2011 - 10:02 PM
Great save Alc! I have an old Craftsman that I use occasionally, I'll keep your wisdom in mind if it ever gives me trouble! Thanks for the post!
#7 daytime dave OFFLINE
  • 4,967 Thanks
  • 6,598 posts
Posted March 08, 2011 - 10:05 PM
Alc, was yours perhaps the 32 cc black Sears best version. I remember tearing mine apart, trying everything I could and finally scraping it. I'm sure I never checked those bolts.
#8 mjodrey OFFLINE
Posted March 10, 2011 - 03:18 PM
:ditto:
#9 trigger OFFLINE
trigger
  • 1 Thanks
  • 13 posts
Posted March 20, 2011 - 05:47 AM
Had a Stihl that did that.Couldnt understand why it was running so bad LOL
