Simple fix for fuel starved Stihl 036.
#1
ONLINE
Posted February 16, 2015 - 08:00 PM
I pulled the carb back apart and removed the fuel strainer screen this time. As the fuel dried on the screen, a whitish haze appeared. I held the screen up to the light and the screen was 80% blocked. I cleaned the screen with a Q-tip and some gun cleaning solvent until I could see that the screen was 100% open. I reassembled the carb, installed it, and the saw runs like new again. I bought the saw 10 years ago and I haven't had to rebuild the carb yet, just cleaned it twice. I will be rebuilding the carb next time around since the gaskets and diaphram are showing effects of this junk gas.
Anyway, just wanted to mention how important it is to clean that screen once in a while. Here's the crap that was in the carb when I first took it apart.
- DougT, Bud, MH81 and 7 others have said thanks
#2
OFFLINE
Posted February 16, 2015 - 08:15 PM
Little passages and little screens are very important in a carburetor!
Ben W.
- boyscout862, Copperhead300 and classic have said thanks
#3
ONLINE
Posted February 17, 2015 - 05:05 AM
I have a O31 sawI think it is,,,smaller saw. I only use regular 87 octane as the higher octane has more additives which when left for a period of time turns to ugly and eats the fuel line which is the only engine related part I have replaced on my Stihl in 20 years. My saw sometimes sits idle for 6 months full of fuel and no issues.
- boyscout862 and classic have said thanks
#4
OFFLINE
Posted February 17, 2015 - 07:10 AM
Thanks.
- classic said thank you
#5
OFFLINE
Posted February 17, 2015 - 12:10 PM
Those little passages are usually the issue for me. They are difficult to get clean.
- Copperhead300 and classic have said thanks
#6
OFFLINE
Posted February 17, 2015 - 01:14 PM
Best way I have found to clean carb passages from my big tractors down to my chainsaws is get a can of air designed for dusting computers from an electronics department. They have a little straw and have quite a bit of pressure for cleaning out the small passages. The other good thing is that since they are for cleaning electronics they aren't just air there is some propellent and so they are moisture free. Those little cans have saved me a lot of frustration of the years.
- HDWildBill, Copperhead300 and classic have said thanks
#7
OFFLINE
Posted February 17, 2015 - 02:27 PM
Yes, I agree. I keep a can in the shop and in my office.
