MF530 dozer blade for the 14, 16 tractors
9 replies to this topic
#1 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted February 16, 2015 - 05:01 PM
I bought this blade a yr or so ago, was told it was made for the MF14 and MF16 tractors. The blade for them is MF530, as far as I know there is only 1 version of them, they are all the same.
BUT the one I have looks different and fits the 14, 16 tractors. ??? :wallbanging:  :wallbanging:  :wallbanging:
There are no #s on it, it is 48" wide what it should be, but it does not look like or fit the way the Massey MF530 manual says or what shows on the AGCO parts book site.
Manual  http://gardentractor...uson-530-blade/
Differences I find.
Front bracket has to be mounted on the inside of the front bumper.
When the blade is angled and down it clears but when it's angled and up the front bumper hits the trip spring. Main frame needs to be longer as the blade is too close to the front of the tractor.
Also hits the bottom of the front axle when up.
The rear bracket bolted to the hitch so that the blades frame is as far forward as possible, the way the manual shows..
Looks to me like part of the plows frame was ground away to clear the tranys drain plug.
Also has 2 lifting points, one for the 14/16 tractors and one for the 10/12 tractors. The bracket that is not being used is for the 10/12 tractors and rubs on the hyd hoses, need to cut it off.
However it does fit my MF16 and it works including the angle lever.
I think somebody went to a lot of trouble to make a MF630 blade for a 10/12 tractor fit where a MF530 blade for a 14/16 tractor should be. They also have changed the blade from 42" to 48".
As long as I don't lift it all the way up it works.   :dancingbanana:  :dancingbanana: :dancingbanana:
  • KennyP and propane1 have said thanks
#2 KennyP ONLINE
  • 53174 Thanks
  • 53311 posts
Posted February 16, 2015 - 05:10 PM
Maybe they had the right blade and made the frame work? Or bent the right frame and swapped to this one?
  • DH1 said thank you
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted February 16, 2015 - 05:20 PM
I think your right it seems to be  combination of 2 different blades.
#4 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 16, 2015 - 05:21 PM
That's pretty odd Doug.
From agco.
Shows the oil drain plug notch.
MF12 blade- the flat bars are welded on straight, not
angulated up.
MF1450 hitch mount and tube are different.
That's real odd, that the front guide doesn't go ahead of the
bumper.
Prev owner must have shortened it, and added the MF12 brackets, so he could
use it on his 12.
#5 KennyP ONLINE
  • 53174 Thanks
  • 53311 posts
Posted February 16, 2015 - 05:31 PM
That's a possibility! Doug, when you take the other lift brackets off, cut the welds and see if there is paint behind those!
#6 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 16, 2015 - 05:48 PM
There's got to be a splice weld in the tube as well, otherwise it wouldn't be hitting the
axle.
#7 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted February 16, 2015 - 05:50 PM
In the 6th picture in OP, why is there that flat spot on the top of the
tube?
#8 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
I think it's a 10/12 tube made to fit the 14/16. It has impressions in it that make no sense for a 14/16 tractor. ???
#9 DH1 OFFLINE
DH1
    Electric Tractors
  • 5497 Thanks
  • 5633 posts
Posted February 16, 2015 - 05:51 PM
tube?
Yes
#10 ckjakline OFFLINE
ckjakline
  • 1192 Thanks
  • 1177 posts
Posted February 16, 2015 - 06:08 PM
I have a 530 snow blade mounted on my one 14.They go ahead of the bumper just like the 10,and 12.They have a different guide mounted to the front bumper than the 10,and 12.On the 1200 I bought last year it came with a blade with no numbers on it.I havn't mounted that blade yet but it resembles the 620 blade.That blade doesn't have the guide on the front though.
Edited by ckjakline, February 16, 2015 - 06:13 PM.
