Sleeve hitch
20 replies to this topic
#16 Sawdust ONLINE
Sawdust
  • 6,009 Thanks
  • 3,490 posts
Posted March 21, 2015 - 06:10 PM
If the bones are too cold the body just dosen't want to move. Hope your feeling better soon. Since I mentioned that forge to Kenny I've been wanting to make another one. When I made my sleeve hitch for the MF 12 when heated it bent like butter. I'm looking forward to watching your project. I just may have to get a press brake then :)
  • hamman said thank you
#17 philips100 OFFLINE
philips100
  • 72 Thanks
  • 82 posts
Posted March 29, 2015 - 10:18 AM
I made a sleeve hitch for my MF12G and was concerned about the round stock used where the hitch pin goes. I wanted to use tubing with a 1.125" diameter so that I would not have to worry about strength and wear later on. I didn't have much luck trying to drill and fit black pipe nipples in each other so I turned to McMaster Carr and found exactly what I wanted. Hope this helps someone with the same issue.
1
Each
  • limebuzz, MH81, hamman and 3 others have said thanks
#18 hamman ONLINE
hamman
    Homelite Owner Extraordinaire
  • 6,560 Thanks
  • 2,900 posts
Posted April 04, 2015 - 01:39 PM
Hoping these pics will work. Had a problem with the card. Here is what I have for the sleeve hitch build.I tried to bend the steel on the press but the jack is bleeding down. I have a kit to rebuild it on the way. I ended up using the acetylene torch and the vise to bend it. Needed to apply a little more heat next time to bend it easier. As soon as it warms up again I will get out there and weld it up. I have tried it on the Homelite already and it fits and pins to it good. Here are the pictures.
1/4" X 2" X42" steel
Bent in the U shape and 5/8" and 1/2" holes drilled.
With the bolts installed, and nuts ready to be welded on.
Tube to be used for pin.
Thanks. More later after all the welding is done when it gets warmer.        Roger
  • KennyP and Sawdust have said thanks
#19 I Carey No Cash OFFLINE
I Carey No Cash
  • 7 Thanks
  • 14 posts
Posted April 21, 2015 - 09:23 PM
I want to make a sleeve hitch for my 1250 cub and have been wondering about the legnth. Does it make a difference when pulling a plow or box grader if the implement is closer or farther away from the back of the tractor? Does it do something to how the weight is transferred?
#20 KennyP ONLINE
  • 40,083 Thanks
  • 46,746 posts
Posted April 22, 2015 - 08:22 AM
The sleeve hitch should be at a factory length. Making it longer will make it harder to lift whatever is attached to it.
  • TomLGT195 and I Carey No Cash have said thanks
#21 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted April 22, 2015 - 10:32 AM
You want the mounting as close as will allow proper movement of the grader blade angling. Too long a hitch makes the front of the tractor light Too.
  • KennyP, TomLGT195 and I Carey No Cash have said thanks
