Large Frame Spindle,Tie Rod,Drag Link Repair Kits
6 replies to this topic
#1 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted February 16, 2015 - 10:54 AM
I now have rebuild kits for the Bolens large frame tractors, meet OEM specs,I have package deals on the ball joints or can be bought by the piece:
Ball joints $12.00 ea (cheaper if more than 1)(member price)USA made
Spindle repair kit $57.95 (member price)you get all parts need to do a complete rebuild,ALL parts are USA made,these are for the 1886-03 up to the early HT-23,these may also work the early large frames,am doing some research,would eliminate the felt washers and replace them with the O-ring
Spindle repair kit for the 1250,1455,1476,1477.1886-01-02 with felt seals $57.95 (member price
Tie rod kit(2 ball joints) $22.00 (member price)
Tie rod and Drag ling kit(4 ball joints) $40.00 (member price)
Single spindle rebuild kit,1886-03-Early HT-23, $29.00 (member price)
Single spindle repair kit for the 1250,1455,1476,1477,1886-01-02 $24.95 (member price) with felt seal
Buy with Confidence,over 2900 positive feedbacks on E-Bay,Thanks, Rick
Edited by blackjackjakexxix, June 13, 2016 - 10:00 PM.
  • Alc, case442, WrenchinOnIt and 11 others have said thanks
#2 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted February 17, 2015 - 11:48 AM
Ok, from what I'm seeing on the parts manual,all the LF's used the same front axle,1718602,(except.,late HT-23's 2389s)the spindle numbers are different but that's because of the mounting of the frount wheel(ex the HT-20 uses a hub assembly and the 1250.1455,1476,1477,1886-01-02 doesn't)but the part of the spindle that goes into the axle are the same dia.(1"),there for this spindle kit will work,you would be replacing the felt seal(1250,1455,1476,1477,1886-01-02) with the rubber O-ring,now this spindle repair kit won't work on the later HT-23's 2389s(they had a bearing assembly in the axle)and a different axle part number
Edited by blackjackjakexxix, February 17, 2015 - 11:53 AM.
  • greystone and holdenboy1960 have said thanks
#3 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted February 24, 2015 - 07:04 PM
Have just added spindle repair kit for the early LF's with the felt seal
  • greystone said thank you
#4 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted February 25, 2015 - 01:23 PM
All the parts books I have show ALL the LF's used the same frount axle,same part number,which would have the 1" spindle shaft in the axle, the late HT-23 show's a different axle part number
Edited by blackjackjakexxix, February 26, 2015 - 09:56 AM.
#5 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted February 26, 2015 - 09:59 AM
Wilberj,ALL them used a 1" shaft through the axle housing,3/4" was the shaft size where the wheel went on,nothing to do with this rebuild kit
  • wilberj and greystone have said thanks
#6 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted February 26, 2015 - 10:00 AM
Edited because my Question was just answered!
Edited by Bruce Dorsi, February 26, 2015 - 10:01 AM.
#7 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 2,952 Thanks
  • 2,105 posts
Posted August 09, 2015 - 01:18 PM
Now have the spindle rebuild kit for the late HT-23's,HDT1000
