No Spark
6 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted February 15, 2015 - 02:11 PM
The Kohler K241 on my 102 is not getting spark put it getting power because I shocked myself. I cleaned the points and put another new spark plug in and still nothing. Any idea what it could be ?
#2 boyscout862 ONLINE
  • 13,440 Thanks
  • 9,385 posts
Posted February 15, 2015 - 02:33 PM
Check the plug wire for a short. Whenever you have a problem, check the troubleshooting section of the engine manual. You can download the manuals from our Manuals Section(3 for free per day). Good Luck, Rick
#3 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted February 15, 2015 - 02:41 PM
You get jolt from wire, but no spark?  You ARE grounding the plug to clean spot right?  Sometimes laying on head with paint on it doesn't work well. Might try condensor, should be mounted on or near your coil.
#4 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted February 15, 2015 - 03:08 PM
I know you said you cleaned the points. Did you pull the points off and check behind them. They are notorious for getting a film of oil on them. Points push rods get a little worn and they will start dribbling oil there. Something to check. As others have stated try a different plug wire.
#5 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted February 15, 2015 - 05:32 PM
I forgot to post I fixed it. I had to borrow the coil from the 129 the old one is shot.
#6 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted February 15, 2015 - 06:39 PM
Glad you figured it out! I've been through Waco and Temple a few times!
  • bbuckler said thank you
#7 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted February 15, 2015 - 06:41 PM
Yeah but I keep borrowing parts from the 129 I'm going have some troubles later when I restore.
