angles?
22 replies to this topic
#1 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,146 Thanks
  • 6,487 posts
Posted February 15, 2015 - 12:20 PM
I never paid attention in geometry.
I am doing trim. I have a wall that goes
Straight 45 straight. How do I figure out the angle to cut my trim.
  • hamman and Coventry Plumber have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted February 15, 2015 - 12:26 PM
A squared + B squared = C squared.
Triangle 6" base and 6" leg... What is the length of the diagnal?
6 X 6 = 36 + 6 X 6 = 36
36 + 36 = 72
Square root of 72 is 8.485 "   The diagnal is 8.485" this example.
  • hamman, IamSherwood and toomanytoys84 have said thanks
#3 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted February 15, 2015 - 12:27 PM
OH, I thought you were working a traingle....
The 45* wall will have both left & right trim cut at 22.5*
  • hamman, IamSherwood, boyscout862 and 2 others have said thanks
#4 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,146 Thanks
  • 6,487 posts
Posted February 15, 2015 - 12:36 PM
You are awesome. How do you figure that?
I am not good at angles
  • hamman said thank you
#5 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted February 15, 2015 - 12:38 PM
45 divided in half
  • hamman, toomanytoys84 and Auburn David have said thanks
#6 KennyP ONLINE
  • 41,527 Thanks
  • 47,427 posts
Posted February 15, 2015 - 12:39 PM
It's half of 45°. You beat me Aftershock!
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,146 Thanks
  • 6,487 posts
Posted February 15, 2015 - 12:42 PM
That makes perfect sense....
  • hamman, KennyP and Auburn David have said thanks
#8 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted February 15, 2015 - 12:44 PM
Well, I wasn't that good in school, but have messed with a lot of math/geometry business over the past 45 years, and I just remembered (some) if it!!
  • Alc, hamman and toomanytoys84 have said thanks
#9 Cat385B OFFLINE
    HAZMAT CAT
  • 14,458 Thanks
  • 10,184 posts
Posted February 15, 2015 - 12:50 PM
Rip a stud at a 45 and fill that center gap on both sides if you're sheet rocking it. They make corner bead at that angle for mudding, if you need it.
  • hamman and toomanytoys84 have said thanks
#10 KC9KAS ONLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted February 15, 2015 - 12:54 PM
He is past that...He is putting the trim on!!
#11 Jazz OFFLINE
Jazz
  • 2,713 Thanks
  • 1,568 posts
Posted February 15, 2015 - 01:37 PM
wood filler is your friend
#12 UncleWillie ONLINE
  • 16,426 Thanks
  • 9,039 posts
Posted February 15, 2015 - 02:10 PM
I wouldn't trust that the wall is actually true. Get something like this and find each angle. Don't tryst that the other carpenter could do math either./
  • Alc, hamman, IamSherwood and 2 others have said thanks
#13 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted February 15, 2015 - 02:22 PM
hope this helps
  • Gtractor, hamman, WNYTractorTinkerer and 1 other said thanks
#14 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted February 15, 2015 - 03:29 PM
Neither was, or am I. I usually have to cut three times and it's still to short !    Glad these guys got you the help.                                        Roger.
  • WNYTractorTinkerer and toomanytoys84 have said thanks
#15 Nxt2doc OFFLINE
Nxt2doc
  • 630 Thanks
  • 335 posts
Posted February 15, 2015 - 03:36 PM
Angles on walls in homes are rarely as precise as the angle on your miter box. Have you ever used a coping saw. This couple of minutes might very well be worth your time.  https://www.youtube....h?v=W8ccy0wLErQ This allows for all of those inside corners that invariably wont match your miter saw.
