Ariens ST824S Impeller Bearing Failure
10 replies to this topic
#1 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted February 13, 2015 - 09:54 PM
During the last brutal 2" snowfall, my FIL's trusty Ariens was making a clunking sound. It seems after 26 years the main bearing on the impeller shaft decided to check out.
The last 'S' on the model number means it's a convertible, you can put a mower deck or a broom on the front instead of the snowbower.
So we split the unit after getting the coupler loose from the shaft.
Bearing is just behind that, right at the snowblower housing. 1.75"x.75"x.50" shielded bearing.
We'd slap it back together, but the original belts are kind of iffy. So belts tomorrow, then ready for another 20 years.
  • MH81, Alc, IamSherwood and 2 others have said thanks
#2 shorty ONLINE
shorty
  • 5,774 Thanks
  • 5,390 posts
Posted February 14, 2015 - 04:41 AM
If it has been trouble free til this happened, he has a good machine.
 My son wants one of those, with all the attachments. He says it will be his and then I will need permission to use it. :D
#3 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted February 14, 2015 - 05:59 AM
That lasted a long time. Yeah, I'd put belts on it too!
#4 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted February 14, 2015 - 08:01 AM
Fix it and keep using it, it's much better built than any of the new ones out there. While you have it apart would be a good time to check the wheel drive for wear as well.
#5 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted February 14, 2015 - 08:32 AM
Those hard plastic gears look like new under there, no worries there. Slight adjustment, then lubed the drive chain.
The belts necessary are 3/8" x 33.5" for the engine to drive, and 1/2" x 36.5" for the accessory drive.
#6 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted February 14, 2015 - 08:36 AM
Here's a video of the available mower deck you can put on this snowblower.
  • Bolens 1000, olcowhand and JDBrian have said thanks
#7 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted February 14, 2015 - 03:19 PM
Wow! Seems noisy, hope just the video then.  Yard that big I would need a rider, and doesn't look like the best cut either.  I bet hands get tired if they still have those safety levers to hold like on my little blower.
Edited by glgrumpy, February 14, 2015 - 03:20 PM.
#8 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted February 14, 2015 - 05:42 PM
Thanks so much for that video, Scott. sitting here looking out at 3 feet of snow I could almost smell the fresh cut grass when I watched the video. The cut looks good to me and that's a great looking yard and all the lush green grass and leaves just kinda hit the spot and helped me over the mid winter blues that make some folks so grumpy!
  • IamSherwood and shorty have said thanks
#9 MH81 OFFLINE
Posted February 15, 2015 - 08:10 AM
Here's a video of the available mower deck you can put on this snowblower. https://www.youtube....h?v=iUglmqziVFU
Is that your mowing deck CAT or is that a random video?
#10 Texas Deere and Horse OFFLINE
  • 14,863 Thanks
  • 15,511 posts
Posted February 15, 2015 - 08:45 PM
Good looking convertible, I bet it would do a nice job once you figured out how to run it.
#11 Cat385B ONLINE
    HAZMAT CAT
  • 14,261 Thanks
  • 10,109 posts
Posted February 15, 2015 - 10:47 PM
Random video, I'm still looking for one.
