Electrical troubleshooting
40 replies to this topic
#31 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted August 22, 2015 - 05:52 AM
How do test my rectifier on lgt 145 hydrostatic
:wave: Welcome to the forum!Try page 100 of this manual
#32 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,244 Thanks
  • 4,503 posts
Posted August 23, 2015 - 09:33 AM
You should have an AMP meter on the LGT. Don't listen to me talking in the video (I get Parallel and Series mixed up). Amp meter is in series with the battery, volt meter in parallel. Hopes this helps. https://www.youtube....h?v=Sgb7yh2L8tM
#33 788524 OFFLINE
788524
  • 2 posts
Posted November 05, 2015 - 09:02 AM
I have a question about my Craftsman 27HP 54 deck model 917.288740. Under the hood the PTO switch has 8 contacts (3-3-2) but the wiring plug only has 7 (3-2-2). Is a wire missing? There is a wire free but it is very short and barely makes it to the PTO switch. How can I determine where the wire goes? I am having trouble with my electric PTO clutch and have just ordered a new one today. But it's the wire floating around free that I am concerned about. Can I get any directions please.
#34 788524 OFFLINE
788524
  • 2 posts
Posted November 05, 2015 - 09:10 AM
Does anyone know of owner of a Craftsman 27hp 54 inch deck model 917.288740 that I can get information from. Because I have some questions about wires under the hood.
#35 Paulgo ONLINE
Paulgo
  • 720 Thanks
  • 471 posts
Posted November 05, 2015 - 04:12 PM
Did you try posting in the Sears forum?
http://gardentractor...-tractor-forum/
Good luck, Paul
#36 KennyP ONLINE
  • 40,043 Thanks
  • 46,732 posts
Posted November 05, 2015 - 04:26 PM
I just uploaded an Owners Manual from Sears Parts Direct!
#37 Djahn31 OFFLINE
Djahn31
  • 1 posts
Posted November 21, 2015 - 04:38 PM
Where is/are the fuse/fuses on a 1968 John Deere 110H?
#38 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted February 14, 2016 - 08:18 AM
Q, is it necessary or an advantage to have a solenoid for the starter system on the Briggs & Stratton 8 to 12 PH engines ??
Shane
#39 MH81 OFFLINE
Posted February 14, 2016 - 11:23 AM
Shane
The key switch will wear out much faster without.
I advise with.
#40 Beef OFFLINE
Beef
  • 45 Thanks
  • 50 posts
Posted December 17, 2017 - 06:46 PM
A digital meter will mess with you. I was a Can-maker electrician and troubleshoot a lot of circuits ,A digital screwed me up a few times after that I used a swing meter Simpson meter . My apprentice called it the old man meter but it was true readings because it put a load on what I was checking.
#41 jolyon39 OFFLINE
jolyon39
  • 1 Thanks
  • 6 posts
Posted January 06, 2018 - 05:21 PM
Most unusual electrical problem I ever had was on a Briggs and Stratton lawn mower engine.
This might help someone...........
Could not get the mower to run and I checked everything, totally stripped it but nothing wrong.
I removed the spark plug, grounded it and watched it fire as fulled the start cord................ What could be wrong? My lovely lady said "replace the Spark Plug" to which I thought "what would she know, I have tested it !"
Turned out to be a faulty spark plug that ONLY failed under compression...... hows that? Very tricky!
regards
Jolyon
